Rest In Peace Cutter
Old 05-11-2019, 09:22 AM
Dallas B's Avatar
Dallas B Dallas B is offline
Duke of Rock
Send a message via Yahoo to Dallas B
Default Band Saw Relay Help
I picked up a Delta Bandsaw with a 3 ph motor in it, my shop only has 240vac. Replaced the motor with a 6 hp 240vac, turned it on and it ran for about 1 min and shut down .... Whattttttt ...... pulled the switch out and found a 3ph relay and a Thermal overload. Went to Amazon and pick up a New Magnetic Starter and installed it ... burnt up in 2 min. By now I know this was out of my League .... PLEASE help me ... I have to Resaw over 2,000 feet of 1x3x4 wood , (cut it down the middle). I will put up Pic's .... I need to find the right
1. Magnetic Starder relay
2. A over load
The first Pic is the New relay that I burn up
The 2nd is theOver load
The 3rd is the motor 6hp NEW
The 4 is The Saw
The last is the New...New Relay... will this one work? and work with the old Over load????
If Not please tell me what parts to buy...AMAZON I hope
ID:	150703   Click image for larger version
ID:	150704   Click image for larger version
ID:	150705   Click image for larger version
ID:	150706   Click image for larger version
Dogs are nicer than people. Not only that, but dogs are smarter than horses. *Winner SFT Best Sig Line 2005* ( http://www.indierevoltmg.com/ )
Old 05-11-2019, 11:47 AM
Your last pic is 5hp max.
Woodrow Wilson
Old 05-11-2019, 12:17 PM
Yeah, the relay is rated for 9 KW but only when running 3-phase--single phase at 240V is max of 5 HP. Your best bet is likely to replace the motor with a 3HP single phase unit then everything will match up...
Old 05-11-2019, 12:51 PM
Dallas B's Avatar
Duke of Rock
... Yup I just put out $$ on this motor.... I think i am stuck with it unless It cant be done. Must be a Relay that will work?
Old 05-11-2019, 01:09 PM
I would think you need a starter for a 7HP motor with heaters rated 20% more than the amp draw of the motor. but someone will be here that knows for sure.
Old 05-11-2019, 01:12 PM
Dallas B's Avatar
Duke of Rock
This is the OLD Motor that is a 3 ph
Old 05-11-2019, 02:18 PM
If you look at your first picture
220-240 volts,
1ph single phase,
and
hp only good for 2 horse power.
your motor pulls +6 hp power.
being that your old motor was 2 hp at 6amps
you
may also need to increase the wire size, likely to 10ga min.
Old 05-11-2019, 02:30 PM
Dallas B's Avatar
Duke of Rock
220-240 volts,
1ph single phase,
and
you
yes but the old motor is a 3 ph .... unless I can use just legs instead of 3 .... I really don't know .... I might have to eat this New motor and Buy a 3hp .... really wish I can use the new one somehow.
Old 05-11-2019, 02:34 PM
Dallas B's Avatar
Duke of Rock
https://www.ebay.com/p/2-HP-SPL-3450...d=152632887140
Would this work? for a Band Saw? I think it is for a Air Compressor does it matter..the wheels on that band saw are very large and heavy
Old 05-11-2019, 03:07 PM
You are asking this thing to do resaw work . I think 2 hsp will not make you happy . I think you would be better off with a starter of right size .
