Rest In Peace Cutter
Old 05-06-2019, 08:07 PM
gimpyrobb's Avatar
Default Siphon sand blasting
I am blasting my foundation to prep it for some tuck pointing and painting. What screens do you guys use to sift or clean the sand? I am using my blaster with the vacuum that recirculates the sand and its getting clogged a lot.
Reference here:
https://www.shopfloortalk.com/forums...ad.php?t=50039
Old 05-06-2019, 08:20 PM
Window screen should work, tilt it so the clumps fall off the end.
Old 05-06-2019, 10:06 PM
The sand absorbs moisture from the compressed air.
If it gets too wet it clumps and stops working properly you may need to dry the sand after a few trips through tue machine.
Old 05-06-2019, 10:20 PM
Is this above or below grade? I’m guessing above, just wondering.
Old 05-07-2019, 08:23 AM
gimpyrobb's Avatar
Above grade. Getting ready to paint the foundation and want to seal up a few areas prior. My air is dry, its not clumping. I wasn't sure if there was a certain size of screen to use, thanks for the info gang.
Old 05-07-2019, 05:24 PM
Reference here:
Rob trying to understand this... You are Sandblasting the foundation under the Brick ???
If So why the need for sandblasting...?? Why not High-pressure wash with Clorox... A pressure washer will clean the concrete No problem and Clorox will remove dark spots and the green algae mold...
Old 05-07-2019, 07:44 PM
gimpyrobb's Avatar
Yes, the area under the brick. I am fixing the foundation so it doesn't leak anymore. I'm sure the pressure washer I have would cause more water in the basement that I dont want. The blaster leaves a rough surface for the mortar to stick to too.
Old 05-07-2019, 09:15 PM
Ok, now I see why didn't know there was a basement.
Old 05-08-2019, 05:30 PM
Randyjaco's Avatar
We Texans don't see many basements
"There are three and only three ways to reform our Congressional legislation, familiarly called, the ballot box, the jury box and the cartridge box" (Frederick Douglass)
Do yourself a favor, find America One News Network (OANN) on your cable carrier. 208 on Uverse. News without the Network BS or bias
