Rest In Peace Cutter
Old 05-11-2019, 03:09 PM
You could wire the old motor at 240V, and run a vfd.
Ok, I will ask this question, if the original motor was a 2hp, 3 Phase motor, why did you replace it with a 6 hp 1 phase motor?
Old 05-11-2019, 03:42 PM
Dallas B's Avatar
Dallas B Dallas B is offline
Duke of Rock
Send a message via Yahoo to Dallas B
My shop does not have 3 ph wire.... and I got a very good deal on that 6hp 1 ph....well I thought I did
Dogs are nicer than people. Not only that, but dogs are smarter than horses. *Winner SFT Best Sig Line 2005* ( http://www.indierevoltmg.com/ )
Old 05-11-2019, 03:48 PM
Originally Posted by Dallas B View Post
https://www.ebay.com/p/2-HP-SPL-3450...d=152632887140
Would this work? for a Band Saw? I think it is for a Air Compressor does it matter..the wheels on that band saw are very large and heavy
The "SPL" is a red flag to me, Special
at one time manufactures tried to trick people by rating motors as peek horse power and not continuous HP.
In other words starting peek horse power.
once they got busted they added SPL and what ever fine print that defines what is special. with out the fine print a 2hp motor may be a one horse power continuous.
Also the link states the rotation of the motor can "NOT" be changed so be sure what rotation you need before you buy.
I would consider HF just check their return policy if their motor does not cut it.
Old 05-11-2019, 03:56 PM
Dallas B's Avatar
Duke of Rock
Do you have a schematic on how to wire up a VFD to that 3 ph .... might have to go that way. And I NEVER used a VFD or how it works, might be interesting to do.
Old 05-11-2019, 04:22 PM
This is the OLD Motor that is a 3 ph
First of all the original motor was 2 Hp, why did you triple the size of
the motor??? You should have just got a 2 Hp single phase motor.
By doing that you have to replace all of the electrical wiring and controls,
and you might start breaking things mechanically putting that much power
in the to machine.
Hopefully you can return the 6 Hp motor and get a 2 Hp motor...
Old 05-11-2019, 04:51 PM
Dallas B's Avatar
Duke of Rock
in the to machine.
Yup...I am droping the 6 and looking for a 2 HP 3400 rpm 1 ph right now ... I did not think about all the HP in the 6 .... well I will have one on hand now.
Old 05-11-2019, 05:05 PM
digr digr is online now
I wouldn't be worried about a 3 HP especially for resawing.
Old 05-12-2019, 10:40 AM
Scotts Scotts is online now
1st off, did you ever see this saw run and saw anything?
I would make sure it was not binding anywhere or have a bearing locked up. The saw should pull very low amps once it is up and running. Unless it has a gearbox you should be able to open the guard and turn it with very little effort on the top wheel with the blade on there.
Yes you would be able to break stuff with that motor if you pushed it up to the 6 hp load on it. If you are manually feeding the stock you should be able to tell when you are loading that thing up.
The other thing is the 6 hp motor has a 30 min duty cycle on it. It is thermally protected as well. If you stay well below the max amps you should be able to stretch out the length of run time there.
I see the motor is rated at 25 amps. that is a 10 gauge wire and 30 amp breaker, unless you are 100 feet or more away.
On your electrical parts, contactors, overloads and such will have to be sized correctly to handle max load, others have pointed this out so I wont.
Do you have a clamp on amp meter? This will give you an indication of what kind of health the machine is in.
If the machine is designed to be run on a 2 hp motor the 6 hp should only use a small portion of total load to run the saw unless you bog it down.
If all these electrical burn up parts are happening without sawing anything I would say you have a mechanical bind in the saw or something is not wired correctly. If the overload is the one for the 3 phase motor it is likely low for the single phase motor so it will open up.
Old 05-12-2019, 06:20 PM
Dallas B's Avatar
Duke of Rock
Thanks Scott... I had this 6 hp motor on for a while and Ran it and resaw wood about 2 hrs, turned it off and when I started it up again it shut off with in about 30 sec .... and the 2 pully are free put 2 new tires on it .... its odd how it worked for sever hrs? ... Going to get a 2hp and the right relay now, I am so far behind right now. thanks
