Old 01-02-2021, 01:39 PM
camdigger's Avatar
Roving Reporter
Originally Posted by o7oBaseMetal View Post
Looks nice. Did you cut the circles with some sort of guide or freehand? I have been thinking of making a circle tool for my cutter but still kinda on the fence if it is worth doing.
Not that I do a ton of circle work, but when I do, I just space out a pair of holes in some 3/8" sheet good. I put a pivot through one hole and the plasma's tip through the other. I do not have drag tips for my plasma, and the 3/8" sheet good gives a nearly perfect standoff. FYI, a 3/8" hole in wood gives a great fit on the plasma tip.
I have kept scraps from assorted carpentry projects, so I have a stock of scrap 3/8" sheathing material for such uses. Local codes allow 3/8" sheathing on most residential construction including roof sheathing.
Old 01-02-2021, 04:19 PM
I made a circle jig using a piece of low profile unistrut.
Allows me to slide the torch ring anywhere I want it.
Old 01-03-2021, 09:19 AM
I have a drag tip but I would think I could drill a larger hole to accommodate that. The unistrut thing could work too possibly.
Old 01-03-2021, 03:10 PM
I’ve bought just about every plasma cutter circle jig, ever sold. Always looking for the perfect unit.
Old 01-03-2021, 07:05 PM
LOL
Old 01-04-2021, 07:12 AM
It will cost you.....$2000...
https://www.amazon.com/VEVOR-Another...9762240&sr=8-8
