Old 11-04-2020, 01:55 AM
staybusy staybusy is offline
Question Need Help IDing Some Valves And Brass Fittings
[please do not embed images]
Any idea where these fittings are used, or specific ID would be appreciated!
1) is referencing the valves btw not the obscure item
Old 11-04-2020, 06:40 AM
Default Need Help IDing Some Valves And Brass Fittings
My best guess
1. ?
2.?
3. Air vent. Will release air in a water line and the the water level will raise a float shutting off vent. Used in water heating systems.
4. ?
5. Temperature sending unit.
6. Valve used in refrigeration system.
7. Looks to be some sort of pressure adjustable regulator.
Old 11-04-2020, 10:15 AM
#4 could be a solenoid valve. With the magnetic actuator missing
Old 11-04-2020, 10:47 AM
Looks like some stuff dug from a scrap barrel.
Old 11-04-2020, 02:31 PM
Thanks guys. Most of the brass will probably get melted down into bars, was just curious if there was anything useful for future projects.
