Old 11-03-2020, 09:45 AM
OleDog's Avatar
OleDog OleDog is offline
Default Table build
Here's a little side table I made last week for my brother. He got the stone made and I just l put the steel under it.
OleDogClick image for larger version
ID:	158318Click image for larger version
ID:	158319Click image for larger version
ID:	158320Click image for larger version
ID:	158321Click image for larger version
Sent from my SM-G970U1 using ShopFloorTalk mobile app
Old 11-03-2020, 10:01 AM
Awesome, nice work!!
Old 11-03-2020, 10:10 AM
That is very nice work indeed. Lots of hand work for sure. How did you do the top part? Press?
Old 11-03-2020, 10:19 AM
OleDog's Avatar
I have a Hossfeld bender that I used to make the knot. The top is just butt welded together. I didn't trust myself to get it square using the bender or a press.
OleDog
Old 11-03-2020, 01:05 PM
camdigger's Avatar
Roving Reporter
Very interesting design. I am especially impressed with the integral corner bracing at the top of the legs. The braids and knots are impressive too-partly because they appear to have been done cold with only minor tweaks with heat.
Filed away for future reference.
Old 11-03-2020, 03:24 PM
OleDog's Avatar
The knot was done cold on the Hossfeld. It was a bit of a pain to keep the outside rod from trying to roll up on top of the inside one. The braids were heated with a rosebud to bend them around. I tacked the 3 rods together at the start of the braid to keep them laying straight, and clamped them between a couple of 1/2" plates. I don't think that was necessary, but it gave me a good spot to hold everything in the bench vise.
OleDog
Old 11-03-2020, 06:51 PM
Very nice work, Ole Dog.
I do like ornamental iron a lot.
Old 11-03-2020, 08:28 PM
Did you just buy the top flat stock already stamped with the design?
Old 11-03-2020, 08:48 PM
Thats really nice work.
Old 11-03-2020, 09:01 PM
OleDog's Avatar
Yes that is some handrail I bought from Kings probably 10 yrs ago. It has been sitting on the rack rusting since.
OleDog
