I used to make plow pipes at old job. Take a piece of 1-1/2” schedule 80 pipe, and cut a 3/8- 1/2” slit down lengthwise of the 7- 8’ pipe, that then would slip over the cutting edge of the blade. Weld on couple washers on either end so it can’t slide off end of blade, and weld on couple short chains that would get bungee corded up to top of blade to hold it on. When plowing, the down pressure would hold the blade on, and the round edge would usually glide over the lawns pushing the snow. After couple plows and the ground freezing, there would be a packed layer of snow, then you could take the pipe off. Sent from my iPhone using ShopFloorTalk
Or you can buy a tractor with a loader...
Design to 0.001", measure to 1/32", cut with an axe, grind to fit.. ![]() |
Not for $200.
I was hoping there would be enough slop in the hitch receiver to let the blade pivot a bit. Right now, it only moves up and down 2-3" on the corners.
This is an interesting build for sure. Love the concept..
I have to ask.. has the mount been reinforced? Few diagonals maybe?
_________________ Jennifer If I defend myself I am attacked. My meaningless thoughts are showing me a meaningless world. My attack thoughts are attacking my invulnerability. I'd like to think of something smart, but I don't want to hurt myself. ![]() My google+ page DoALL 36" Another Johnson model J Project Lathe? Maybe..... 1958 SBL 13" Yeti Esseti Aka running welder on 3phase. |
The blade is also built lightweight with a 16 gauge mouldboard face, 3/16" x 2" angle, and 1 1/2" wide 10 gauge ribs spaced 15". The blade will crumple up like a beer can before doing damage to the receiver mount, IMHO.
Not to mention some nasty snakes, kudzu and ultra high humidity...
If you build the front hitch, you might consider two receivers for mounting. It would require a mod, but would be a lot stronger. |
Yet, I feel pretty lucky.
I grew up on the southern shore of Lake Erie... In the summer, we commercial fished all the way to the Canadian side, in the winter, we drove junkers to port Dover, to party. (we always went in 2 or 3 cars, so one would make it back by sunrise.) Now, in my later years, I can't handle the cold well enough to hunt Pennsylvania, Ohio or Michigan like I used to. Now it's pick up trucks or jeeps with heaters and plug in sox. The canned hunts that are my speed now, the only thing I have to pull is a trigger... Gator's and snakes or leeches, oh my. we do have seasons this far south. Hot, then very hot and muggy with tropical rain. Snowbirds are turning into movedowns at an alarming rate and turning the state red by shades. I just can't pass up a chance to stick the snow people with a friendly needle. RED
A 160 MPH drive, down a 2 lane blacktop, all by yourself, is NOT anti-social behaviour... I drag race because football, baseball, and golf only need ONE ball. Paul. What I really need to know is, WHEN DOES THE SHOOTING START? |
