  #1271
Old 01-01-2021, 10:34 PM
Having seen what rodents will do to fibreglass batts, in your position, I would cough it up and spray it. At the end if the day it’s your choice. I hope to never have to use the stuff again if I ever do any building or renos for myself that involve insulation.
  #1272
Old 01-02-2021, 12:03 AM
Couple thoughts. Maybe right, maybe wrong, someone will correct me if I am wrong.
If you go with spray foam insulation, done right, it will be airtight. That does a lot to stop heat transfer in spots you do not want to to go. That R-15 of spray foam may perform better than the R-39 batt insulation.
Old saying of buy once, cry once comes to mind. Build it right now, it is hard to come back 20 years from now and do it better.
Are you planning any type of storage catwalk above your lathes and mills along the outside walls? I see a lot of potential storage space in those tall ceilings. And the way you are collecting tools, you will need all available space you can get.
Possibly if built right, you could incorporate some sort of lifting beam crane to be able to load bigger shafts into the big lathes, attaching it to the lower ceiling/ floor of storage floor.
  #1273
Old 01-02-2021, 07:57 AM
randydupree's Avatar
Why, Hell Yes!
Yes,and we also have bugs of all kinds and sizes that love to get into fiberglass
insulation.
foam it and you will never regret it.
  #1274
Old 01-02-2021, 12:24 PM
OldRedFord's Avatar
Kibble King
How does spray foam react to roof leaks? Hide it until it's too late?
Tim
  #1275
Old 01-02-2021, 03:14 PM
Never seen it happen, so I’m only guessing. Since it more or less bonds to the surface, I can’t see the water wicking between the steel and foam. Not sure if it would eventually come thru or not....I doubt it.
The stuff they use around here is a high density, closed cell foam, similar to styrofoam SM.
  #1276
Old 01-02-2021, 08:39 PM
OldRedFord's Avatar
Kibble King
Started running wire today.
ID:	159056   Click image for larger version
ID:	159057   Click image for larger version
ID:	159058   Click image for larger version
Tim
  #1277
Old 01-02-2021, 09:53 PM
Too late now but I always put outlets 4' from the floor. Stops all that bending over crap.
  #1278
Old 01-03-2021, 08:06 AM
Why, Hell Yes!
I agree with you!
  #1279
Old 01-03-2021, 08:13 AM
I did that in the mud room I built couple years ago. I enjoy the convenience over looks every day.
  #1280
Old 01-03-2021, 04:03 PM
Norm W's Avatar
Norm W Norm W is offline
If you ever end up with some rug rats, they will be much safer with the electric 4' off the floor.
