Old 08-29-2020, 07:15 PM
camdigger's Avatar
Roving Reporter
Default C clamp from scrap
I got frustrated with my cheap c clamps. The body tries to torque when the handle is tightened and the foot or clamp bolt end tries to walk off the work or stuff I'm clamping to.
With a quick trip through assorted resource stashes, I made my own. The pivoting foot is ball bearing mounted for low friction. The nut is welded to the end of the screw so I can use a drill or impact to tighten. A very quick and nasty project, but did the job I needed without a trip to town and without blowing the budget on clamps.
ID:	157541   Click image for larger version
ID:	157542   Click image for larger version
Old 08-29-2020, 07:28 PM
astronut's Avatar
astronut astronut is offline
It will not win a beauty pagent but, if it works and gets the job done that is all that matters!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 08-29-2020, 08:03 PM
Some of the best clamps I have, outside of a Besseys sliding arm, are some old clamps I got at auction called Lobster brand. Very heavy and don'\t flex and twist.
Old 08-30-2020, 02:14 AM
TEK's Avatar
TEK TEK is offline
[HTML[/HTML]
Could be a lube issue.
I've seen guys use neversieze on them before but that just gets messy.
I usually hit em with WD40 real qwik if I need to.....
-----DozerDan
Old 08-30-2020, 07:48 AM
Originally Posted by TEK View Post
[HTML[/HTML]
ooooh….drill & tap for a grease fitting.....
Old 08-30-2020, 09:03 AM
camdigger's Avatar
Roving Reporter
[HTML[/HTML]
In a previous life, we used never seize type thread compounds by the 5 gallon bucket. You can only imagine where that shit gets! Random Hint.... ether starting fluid works on cloth as a spot remover to remove it. Treat the spots, air dry outdoors for 8 hours minimum, then wash and dry as per normal..... As effective as dry cleaning.
Old 08-30-2020, 10:19 AM
[HTML[/HTML]
In general, any oil or grease collects grinding particles and dirt. But a fake lubricant that will disappear is good. WD40 or anti spatter spray will provide lubrication and keep berries from attaching to the threads.
Old 08-31-2020, 06:42 AM
I dig shop made tools, even if they aren’t pretty. I like to study them and get in the mind of the ones who made them. I have a collection of them, had mostly from the scrap yard. I would toss that clamp in my bucket if I found it.
Old 08-31-2020, 07:30 AM
camdigger's Avatar
Roving Reporter
Thanks for that!
I have a few other creations that would keep you entertained for a while. Some work exactly as envisioned, others, not so much.....
Old 08-31-2020, 11:33 AM
Scrapper Greg's Avatar
A 5 gallon bucket of never seize??? Wow!!! Pretty sure someone could coat the whole planet with one!!!
MAGA
