Old 05-27-2011, 04:30 PM
bd354's Avatar
bd354 bd354 is offline
LW, I dredged up some pics of mine taken before the camera was broken ( no it wasn't me). I made this from junk I had lying around. The frame was made of old chainlink fence posts. The tub is 3/16 plate. Having a hitch on either end is the way to go IMO.
ID:	77334   Click image for larger version
ID:	77335   Click image for larger version
ID:	77336   Click image for larger version
Life is easier if ya plow around the stump
Never drink downstream from the herd
Old 05-27-2011, 06:32 PM
Dang! That's unlike any chainlink posts I've ever seen. Looks more like some sort of H beam that's galvanized.
Your scoop is a carbon copy of what I bought yesterday. Yours is nicely done.
I had to run into Lafayette at noon to HF and picked up a quicktatch affair that I will morph onto the drawbar works of one of the SA's and on to Southern Steel to pick up different sizes in flat bar. I had been working into and past the scrap pile the last few weekends.
But, I'll have to be crafty to be sure and get it together before a Monday comes as Pop's might need use of the tractor. Hmmmmm. Crafty!
Old 05-27-2011, 07:07 PM
bd354's Avatar
Thanks LW. The fence posts were from the local HS football field. Those are probably from the 1960's or 70's. It is a small I beam that's 2 3/4 in. tall and about 2 in. wide. I ground off the galv where I welded.
When I was building the scoop I didn't have anything to reference the
size so I made a WAG. If I really load the scoop to overflowing it's hard to keep my front wheels on the ground. My little 24 hp Kubota pulls it easy enough. Maybe your Dad won't need the tractor this weekend. Good luck.
George
Old 05-27-2011, 08:37 PM
I most probably won't tear into any of this over the weekend. I have a few other hotter irons in the fire. But I now have all of the pieces to make life easier for us old folk.
Old 05-30-2011, 02:02 PM
camdigger's Avatar
Roving Reporter
Originally Posted by LW Hiway View Post
R'Bill, good find on the Fresno Scraper. While looking at that pic and doing a little more looking, I now can tell that two of the old hulks in the weeds look identical to this, see pic. The side C shaped loops are still evident as well as the altered draw bars. Wow, can you imagine how many thousands of tons of material my family must have moved with these things? Or, how many tired mules at the end of the day were fed watered and cleaned?
My folks have an old Fresno scraper,too.
Apparently, they bought it to pay off land taxes by using it, themselves, and their 8 plow horses on local road building during the depression. Last time it was used, Dad hooked it behind a U Minneapolis to drain a bog in front of the cow barn. MANY miles are put on by the operator as he follows along behind handling the reins and the "Johnson bar" cutting/filling, carrying, and dumping. With a good team, a single operator can manage, unless the cutter blade hooks a rock. When that happens, the operator can be flipped up in between the horses....
With the half broke crow bait farm teams my folks had, two are needed, one to manage the team and one to run the scraper.
