SFT Search: |
Thread Tools | Display Modes |
#41
A stone will over heat the material if you are not careful, aluminum gets soft from heat and will pack into the stone. A stone for cleaning up or sizing is ok. not good the choice for cutting out a pocket. There are thin slitting types of stones but I would not allow any student too use them. Quote:
The 25% coupons have been in the penny saver, magazine's, and some free paper they throw on the sidewalk. When I did frequent Libraries the coupons were in every type of mechanics magazines, you may want to check them out. BTW: its only good for one item and not the total purchase. Quote:
In thin material it can be cleaner. Not really faster. Too many teeth can require more pressure = more heat. May break the blade from extra pressure. Less room for chips too escape, chips will pack-up and stop the blade from cutting so you end up pushing harder without thinking and break the blade.
#42
Another idea. How about a mortising attachment for a drill press. If you are cutting .010 to .015 steel, I would think it would go through that without a lot of problem. I would try a 3/8" unit.
MAGA |
#43
new info: Selkirk has confirmed the piece is 100% 0.017" aluminum.
#44
Getting down to the wire. I want to get some kids building these things before xmas, but not looking good.
(Note, Selkirk confirmed the piece is 100% 0.017" Aluminum sheet the coping saw failed. I could not really control the thing. It just got stuck. The blade was too coarse (15 or 20 tpi). Where i did get a good stroke, just got rough edges. No way i could get those sharp turns. You can see in the pic the trace of the square hole i'm trying to cut. Awaiting some fine 360-deg spiral blades in the mail, but not sure they'll fit the Stanley coping saw. http://durafix.com/blades/copingsaw/ and http://www.bestwayproductscompany.com/products.html Also waiting for some Stanley 32 tpi blades designed for this saw. http://www.ebay.com/itm/111231547834...84.m1439.l2649 If the above blades don't work, then on to sub-$100 power tools. These are they: http://turtlefeathers.net/text/power...son-guide.html and http://www.harborfreight.com/16-inch...saw-93012.html and http://www.ixi-devices.com/index.php...aw/flypage.tpl Last edited by johnyradio; 12-19-2013 at 10:55 PM. |
#45
Johny, have you considered a Dremel Multi Tool?
I don't have any experience cutting thin metal with one but I do have the Harbor Freight version that sometimes comes in handy. They just vibrate through the material so you need a way to dampen loose objects, i.e., hold it firmly, but it might work. Here's a . Website.
#46
http://www.shopfloortalk.com/forums/...ad.php?t=40541
#47
Thanks, Curmudg!
Keep in mind, i must cut a 1/3" square. So, most Dremel attachments are too big. I believe the attachments that MIGHT work are:
Someone who is familiar with Dremel, please link me to other attachments that might work. 1/3" square hole, no burrs, sheet aluminum, 3"+ from the edge... Cost: The cheapest Dremel brand tool i'm seeing is about $25, so i'm looking at Dremel-compatible tools, starting around $15: http://www.ebay.com/itm/NEW-80-Piece...item27da046b31 Last edited by johnyradio; 12-20-2013 at 03:11 AM. |
#48
You get a cleaner cut with a flat blade nibbler opposed to round blades that cut half moons.
Still advise drilling 4 holes one in each corner. The penny is a little too soft and cut somewhat gummy. pix 4) One nibbler I was not able to get the penny under the blade, I assume the one with more space is an older nibbler. requires a 7/16 hole to get the cutter thru, may be able to remove the spring-loaded hold down clamp and get it in a smaller hole. As I recall there is some other hand nibblers that do not have the clamp and may allow a smaller thru hole.
* * The factory of the future will have only two employees, a man and a dog. The man will be there to feed the dog. The dog will be there to keep the man from touching the equipment. ~Warren G. Bennis Last edited by GWIZ; 12-20-2013 at 04:35 AM. |
#49
Adel tool co
chicago, ill made in the u.s.a. Thats funny, I typed all capitals and the site changed to lowercase
#50
The wood chisel idea is a good one after you drill the 4 holes.
* * The factory of the future will have only two employees, a man and a dog. The man will be there to feed the dog. The dog will be there to keep the man from touching the equipment. ~Warren G. Bennis Last edited by GWIZ; 12-20-2013 at 05:05 AM. |
Tags |
aluminum, cut, drill, punch, sheet |
