Old 11-13-2007, 09:30 PM
Default WhiteTrash Firewood Basket
One of my ambitions for the forksnatch is to use it to shuttle my little dabs of firewood from the trailer to splitter to my backporch. I am tired of wheelbarrows, being both lazy and generally inclined to finding the easy way of doing things.
1. So I had this old 4 wheel dollie thing that I bought a couple of years ago from the same guy I got the Whiteboy from originally. All 4 casters swivel & it has an adequate angle iron frame. I bought it for 10 bucks just for the casters and it has been in my way ever since so I thought, "why not a rolling pallet?". I don't need it for anything else & if I change my mind, it will still double for use as just a dolly.
2. So I made some sort of fork extensions for the little forklift. There are a pair of inserts that slide into the forks, then inside these white tubing sockets. I cut them at 45° to match the ends of the forks.
3. Then I welded them to the underside of the dolly.
4. A few months ago one of my neighbors dragged a bent cheap-assed futon or bedframe or something out to the alley. Naturally, I dragged it down to my place and salvaged the tubing. I made a backstop out of this piece; the other major piece was bent pretty badly so I used it for ends as you will see later. This stuff is thin wall & very light weight, which is what I had in mind.
5. So I cut the first piece down to size to make the back part of the playpen.
ID:	24912   Click image for larger version
ID:	24913   Click image for larger version
ID:	24914   Click image for larger version
ID:	24915   Click image for larger version
Old 11-13-2007, 09:38 PM
Jim-TX's Avatar
Jim-TX Jim-TX is offline
Chairman of the Headboard
Ahh.... The saga continues.
Old 11-13-2007, 09:39 PM
IDIGDIRT's Avatar
IDIGDIRT IDIGDIRT is offline
That is going to be a nice firewood basket,Cutter. Attachments for the Forksnatch could be endless as time goes on and he will continue to serve you well around the back forty. I agree with leaving the casters on to allow other uses of the same pallet/dolly/basket. Forksnatch will turn in to a swiss army knife for you! Press on my friend.
If the women don't find you handsome-they should at least find you handy. Red Green
Old 11-13-2007, 09:52 PM
1. Then I cut some 2 inch stubs from an old ceiling fan hanger pipe that just happened to fit snugly inside the black tubing; this is so I could weld it back together with .035 wire & my limited skills - burn-through city otherwise.
2. I cut some 1/2 inch pipe stubs about 3 inches long & bolted them to the carefully measured & marked corners of the dolly. The backstop fits over the back pair. The fit here is a little bit sloppy but that's ok - they're just to keep the the thing from sliding around.
3. So the back part looks like this. I just slips down over the little pipe posts
4. I bolted a piece of angle iron vertically to each end of the backstop & welded 2 pieces of the ceiling fan pipe in the appropriate spots (top & bottom) for them to line up with the cut ends of the side frames. Sorry - fuzzy picture. I think you will get the idea when you see the final assembly.
5. Then I welded some additional support into the dolly frame and tacked in the only useful piece of expanded metal that I had on hand.
ID:	24917   Click image for larger version
ID:	24918   Click image for larger version
ID:	24919   Click image for larger version
ID:	24920   Click image for larger version
Old 11-13-2007, 09:58 PM
So finally, the whole thing just sort of snaps together & only weighs 30 or 40 pounds. I can use it with or without the playpen to move whatever junk that happens to need moving without adding too much weight to the load.
I spotted a little dab of firewood scattered around a dumpster down the alley the other day when I took the Kohler out for it's first test spin & had hoped to go snag it today but alas, it was nearly dark before I finished this thing.
Maybe I can field test it tomorrow sometime.
Old 11-13-2007, 10:06 PM
Jim-TX's Avatar
Headlights!!! You need headlights man!!! How do you expect to do alley pillaging without headlights.:evil:
Old 11-13-2007, 10:07 PM
Cutter,
The picture is getting clearer and clearer, the forksnatch, is nothing more than a tool for you to rape and pillage, yours and surrounding neighborhoods of all unattached and undocumented wood. :evil:
Jack
Old 11-13-2007, 10:12 PM
Yes sir Cutter thats a right fine job
Old 11-13-2007, 11:25 PM
Well thanks, guys. I forgot to mention that one reason I was glad to use up that old bedframe was to get it out of my way, same as the dolly. I made it so easy to take down so it can all hang on the fence somewhere when I don't need it.
And my total cost on it besides a few bolts, electricity & consumables is the ten bucks I paid for the dolly to begin with. Every thing else was scrap that I scavenged here & there. My kind of project for sure.
Old 11-13-2007, 11:54 PM
tnfarmboy
Guest
Posts: n/a
Thumbs up
Very Cool!! Another use is as a scaffold…you can lift someone up to change the light bulbs in your shop and they will even have handrail to hold on to.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
