Old 05-14-2023, 10:25 PM
CaddmannQ's Avatar
CaddmannQ CaddmannQ is offline
Default Up the Crack or Down?
I have a 1/8” pressed steel shape that has a 1” long crack at an edge. I have drilled a hole at the end of the crack. Now I am going to weld it up.
Should I weld towards the hole, or towards the edge?
This is mild steel and I am going to use the TIG welder.
Old 05-14-2023, 10:45 PM
I would control warpage by backstitching
"We live in an era where things that are self-evidently true are denied by maniacs who are then flattered by cowards." Douglas Murrey
Old 05-15-2023, 09:40 AM
CaddmannQ's Avatar
Thank you Ironman.
I won’t try to weld it in a single pass, but I guess I asked the wrong question.
Would you put the first puddle near the edge, or at the hole, or perhaps somewhere in-between?
Since I did not know the best place to start this weld I was going to start in the middle of the crack and jump back-and-forth.
I have total access to weld this from both sides flat on the table.
Old 05-15-2023, 09:58 AM
astronut's Avatar
astronut astronut is online now
I would start the weld at the edge while the piece has not absorbed much heat yet. Less tendacy to melt the edge than if tried it last after absorbing a bunch of heat and wanting to melt the edges away.
Still got the shovel!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 05-15-2023, 01:09 PM
I don't think it really matters.
Old 05-15-2023, 02:05 PM
CaddmannQ's Avatar
It needs a little bit of straightening, and I will wait to do that until after the welding, but I doubt it will have too much warp.
Of course everything depends on my skills as a welder. All things considered, this first little bit of welding should be a breeze compared to what comes later.
But really, I was just curious if there was a general rule about welding up cracks where you have to drill a hole.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
