Old 05-11-2019, 01:46 PM
Rod , some people believe everything must be painted . Former military if it don't move paint it ? It is a mental illness .
Old 05-11-2019, 02:58 PM
NOBLNG NOBLNG is offline
Definitely a bad casting I think. It was originally painted a green by the looks of it.
ID:	150711   Click image for larger version
Old 05-11-2019, 03:24 PM
Dave Lee's Avatar
Dave Lee Dave Lee is offline
Armchair Webbie
Sounds about right. A guy who I do some work for now and then, was in the army in the 60's. He told me that, when they went on maneuvers, his truck had the paint trailer hooked to it. You're on maneuvers and you take paint with you?
Dave
Old 05-12-2019, 09:44 AM
4gsr 4gsr is offline
Just from past experience with steel castings. A poured steel casting on a good day will yield a casting with a very rough finish. And usually has blow holes imperfections that have to be weld repair or ground out. Where with a grey or ductile iron casting, you can get a nice cast finish without doing much finishing to the casting. Not saying to stay away from steel castings, they are just much harder to cast than cast iron is. There are foundries that cast all sorts of steel out there and they produce very nice castings. It's obvious, that casting was not done in a foundry that knew what they were doing.
Ken
