![]() Edit: he says 162k miles on it |
Read about Cam Phasers before you go too far. I am not well versed on the 6.2 but I believe it uses the phasers and they can be noisy until oil pressure is up, but eventually they go bad and it is a major undertaking to change them.
Handcrafted Leather |
Personally, I would not touch it with a 10Ft pole unless it is damn near a giveaway. Just my 2 cents
The 6.2's that I've driven were better in every way than the old 5.4 but I don't know how many miles they are good for before things get expensive.
Wont take much to buy it, prob 2k or less, he wants it gone.
Yeah been reading on the cam phasers. Also the intake runners, as sources of knocking. Complicated. Be nice if it was a simple fix, and it'd be a truck I could use since I somehow broke the ZF6 transmission in my other 7.3 truck. |
Are you going to do the work yourself? If the springs are broke, you should pull the heads and inspect for bent valves and piston damage. Know of the phaser issues on the 5.4 and 6.2, I would replace that and the timing chains and refresh the engine. But for a couple grand in parts your time and the initial purchase you would have a good truck. With those phasers 5k oil changes with a "synthetic" engine oil would be highly recommended. That system is very sensitive to oil condition.
Also will your buddy let you pull the valve covers and inspect for broken springs or dropped valves before buying.
And I moved the thread.
He probably would let me, but I don't want to work on it where it's at. It's about 3 hrs from me and it's just a pain to bring my tools and work in the dirt. |
Yes, I'll be doing the work. I'm not the quickest but don't mind tearing in. The body is still presentable but the underside has gotten some rust from being driven on dirt roads then sitting for 3 yrs on dirt due to this knocking issue. It was also a former oil field truck, part of a fleet. It is just a work truck. Some other people have thrown some parts at it, plugs, coils, wires, etc. And maybe a few sensors, but have not torn into the engine, ie. the valve covers and front timing cover. For what he's wanting, I don't think I can go wrong. Worst case, part it out. |
Kind of Like us. We kept having field failures on 8 lug wheels but only in mine operations in Canada . We figured the 3/4 ton was being loaded as a class4 .
