  #91
Old 11-12-2022, 09:05 PM
Originally Posted by gimpyrobb View Post
Sweet work! Before I'd mess with the IP, I'd pull the injectors and have the pop pressure and spray pattern checked. There is a place called diesel injection service near me that does it for free. Might call around and see who near you does it.
+1 get the injectors checked first that pump unless you are blessed to have an old school dude still running a flow bench that can fix it is going to come in around 2K
  #92
Old 11-13-2022, 12:44 PM
Here is some video I shot yesterday..
I love seeing all 4 wheels turning.. It's so slick and sloppy but this machine did well.. Didn't get stuck and it moved the pile so much easier then expected.
There is no level gauge for bucket level and the very bottom of the cutting edge is worn away in the wrong direction.. So will have to put a level gauge back on.
So at some point I'll have to weld on a new cutting edge.
Video: No expert on machine operations and the video starts off with photos, then sped-up footage, then getting to the meat and potatoes.
https://youtu.be/0lnJmxw2xpo
So Jen, some thoughts...
Even though the engine is running rough, it has lots of power.
As a temporary measure, set the bucket down on a level surface and ensure the bucket isn't curled up a bit. Weld on a piece of FB about 2 ft long on the top edge of the bucket pointing back toward you. Now when you are operating that bar will tell you the relative position of the bucket bottom.
To fill a bucket, raise the boom about 5 inches and curl the bucket down til the lip is touching the ground. Drive forward and just as the bucket stops advancing and the wheels break free you curl up a bit and then drop the lip down and the machine will advance into the hollow in the pile you just made. Repeat the up and down bucket motion til the muck is coming to the top of the bucket, and then roll the bucket up and you are full.
You need a new lip.
For snow and manure a mild steel 1/2" plate will be fine bolted on.
Consider a spade lip. If you take a piece of 1/2 x 8ft plate and from center of one edge cut the plate back toward the end removing 4-5" at the end of cut, and do the same for the other side. That slight point will punch into a pile like a knife into butter, especially if you are mucking as explained above. And for back dragging to level it has almost no effect.
Hope this gives you some ideas.
One of the things my dad taught me is that the world is your bathroom -- Quick Dick McDick
  #93
Old 06-19-2023, 09:29 AM
Thanks for the info guys.
The beam sticking out where it can be seen is a neat idea.
So update time.
I installed new batteries few months back.
Left them connected only to find after 5 start cycles the batteries were flat.
I recharged the batteries and put a meter on the batteries while running. 12.3V. No charging.
After that I put a disconnect on one terminal and would just disconnect the battery when not in use.
I finally broke down and bought a cheapo single wire alternator and had to make a mount.
Figuring out how to mount it was a problem since nothing is plumb to the face of the engine pulley.
I made a wedge as a first thought to face mount it.
After some thought I fell into this design which made it not need to be matched to the front pulley and would be easily aligned once welded into place.
I used 1 of the original mounting holes for the generator and used 4 bolts in original position.
It's super rugged and can be unbolted easily.
So the old generator can be installed should need be.
ID:	168172   Click image for larger version
ID:	168173   Click image for larger version
ID:	168174   Click image for larger version
_________________
Jennifer
My google+ page
DoALL 36"
  #94
Old 06-19-2023, 12:02 PM
Unless it is sold to a restorer .You will never go back .
  #95
Old 06-19-2023, 01:02 PM
Nice work.
Is the chrome good for an extra 10 amps?
  #96
Old 06-20-2023, 04:49 PM
I'm pretty sure you are correct. But in case someone in the next life after mine wants to restore it, there won't be anything in the way.
Nice work.
10amps and huge looky, looky blingy factor.. LOL..
Will be all the talk if the unit ever makes it to a show.
_________________
Jennifer
My google+ page
DoALL 36"
