Old 03-27-2021, 06:41 PM
That is an amazing piece of equipment
Old 03-28-2021, 08:27 PM
4-13-1949 to 5-21-2023
Originally Posted by Tim KS View Post
I'd like to have a stripped down version just to get around rough areas. I don't need the PTO (the chain drive there looked a bit like a weak link), and no need for a lot of the finer controls......just a higher clearance & rubber tracks for exploring....basically a fun machine.
Get one of these. Gas, brake and two levers is all you need.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 03-29-2021, 09:23 AM
Kent_323is's Avatar
Kent_323is Kent_323is is offline
Tim,
I'm also just starting production on these:
www.ultimateoutdoorvehicle.com
https://www.youtube.com/watch?v=H7aU2KlCMu8
Goes through mud, water, rough terrain, snow, etc.
Has true zero-turn.
Thanks
Kent
Kent
My shop and projects: www.kustomsbykent.com
Old 03-29-2021, 10:54 AM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
Originally Posted by Kent_323is View Post
Tim,
Has true zero-turn.
Thanks
Kent
That looks like a fun machine, Kent, but I guess at my age I should be happy with my Polaris Ranger......it gets me most places I need to go.
Old 06-29-2021, 11:43 PM
Kent_323is's Avatar
Default Part 9 All Terrain Track Chair final assembly
Part 9 video is now available. I cover much of the small bits that have consumed time over the past few months, and also focus on the winch anchor leg assemblies with fabricating the final pins to replace the temporary pivot bolts.
I also designed, 3D printed, and installed a custom flip out lever handle for the main power switch.
https://youtu.be/jRDmwKcagnI
ID:	160840   Click image for larger version
ID:	160841   Click image for larger version
ID:	160842   Click image for larger version
Kent
Old 08-05-2021, 02:06 PM
Kent_323is's Avatar
And a couple of weeks ago I made further progress on this project by getting the roof on, part of the ramp flipper end, and the windshield frame on. Now working on the final pneumatic's for the windshield frame.
https://youtu.be/B5IWVK3GdRM
Kent
Old 08-05-2021, 09:06 PM
It’s looking like a sharp machine!
Old 09-27-2021, 09:22 PM
Kent_323is's Avatar
Default Part 11 All Terrain Track Chair project
Here's part 11, getting some of the last major components assembled onto the vehicle.
Getting very close to the end!
https://youtu.be/1lnfCEYHitk
Kent
Tags
design, hydrostatic, radio controlled, tracks, welding
