It's obvious that if your wanting any one here to 'buy into' what your wanting to do, it may not happen. With all of the gun forums out there I'm questioning why you would pose your question here and not on one of them. BTW, it may just be one of us 'antique cleaning firearm gunsmiths' that saves some newbe from blowing his ass up. I'm not wanting to have you feeling unwanted or somehow less than stellar in what your wanting to do, but it might be appreciated by the masses here to go another route to bear fruit in your undertaking. FWIW, if this was one of my springers, pumps or PCP pistols, I'd do it myself in a skinny minute. As it is, there is just too much liability for anyone to consider doing this. Hell, I'd feel bad just suggesting how to go about it. As an inside mention, several years ago a friend(loosely used today) asked me to put together a cut apart bunch of pieces of a European hand held machine gun. He's a self-professed collector. After getting assurances from him that it was only to be for display purposes only and having him actually sign a piece of paper with a witness to that fact, the job was done. It looked in all like an operational machine pistol. A month later I find out he's getting sears, springs, firing pins and auto action parts to fire the thing. I called my attorney who called him and the local PoPo to cease. It has once again been turned into tiny pieces. I had a problem with someone firing a gun that had three pieces of the barrel put back together with TIG welding and ground to finish. But again, I'm the asshole. ![]()
God, if you would grant me one request through Prayer, please help me be the Man my Dog thinks I am. Please. Quoting "The Hunt". "A man will walk into hell with both eyes and arms wide open. His dog will know better." I never thought I'd live long enough to become a grumpy old bastard. Here I am, killing it! |
Sally is on vacation - can I help?
madam X - Site Empress for Life Director of Policy, Inane Matters (by appointment) Rated M for MAGA |
GOOD Research POP..!!
Aside from the legal and liability issues... if that frame is indeed made of 7075... instead of 6061 Best not even try to braze or weld it... http://www.alcobrametals.com/guide.php?metal=1#7075 This is what ESAB has to say about it.. How Do I Weld 2024 and 7075? Q - I come into contact with two aluminum alloys of which I have found difficulty in obtaining information about arc welding. These alloys are 2024 and 7075. Can you provide me with information on how to weld these alloys with either the GMAW or GTAW process? A –The reason you are having difficulty finding information on welding 2024 and 7075 is that both of these materials belong to a small group of aluminum alloys that are generally considered as being unweldable by the arc welding process. These materials are often found on aircraft, sporting equipment and other types of high-performance, safety-critical equipment and are not usually arc welded on the original component. Probably, the two most commonly found aluminum alloys within this category are 2024, which is an aluminum, copper, magnesium alloy, and 7075, which is an aluminum, zinc, copper, magnesium alloy. Both of these materials can become susceptible to stress corrosion cracking after welding. This phenomenon is particularly dangerous because it is not detectable immediately after welding, and usually develops at a later date when the component is in service. The completed weld joint can appear to be of excellent quality immediately after welding. However, changes which occur within the base material adjacent to the weld during the welding process, can produce a metallurgical condition within these materials which can result in intergranular micro cracking, which may be susceptible to propagation and eventual failure of the welded component. The probability of failure can be high, and the time to failure is generally unpredictable and dependent on variables such as tensile stress applied to the joint, environmental conditions, and the period of time which the component is subjected to these variables. It is strongly recommended that great care be taken when considering the repair of components made from these materials. It must be stressed that if there is any possibility of a weld failure becoming the cause of damage or injury to person or property, do not perform repair work by arc welding on these alloys and then return them to service. http://www.esabna.com/us/en/educatio...4-and-7075.cfm
. . Pay no attention to that man behind the curtain.. ![]() The more you Know, The Better you Know, How little you Know (old Estonian saying) Last edited by H80N; 10-13-2013 at 02:13 PM. |
No fixation. Just following what I was told I should do by another expert, because that's how HE did it.
Unfortunately most of my reply is me having to defend my position because too many took my 'sally' comment personally. I appreciate the comments, I really do. I didn't expect such a turnout. |
D'Page, take your piece to/find an NDI Lab (non-destructive inspection). You can find them listed in the yellow pages.
They can make a few small tests to give you a close relationship to it's alloy and hardness without destroying your frame.
As I explain the two procedures to my Welding I students, welding is like mixing the eggs, cake mix and other ingredients all together. Once done correctly, you cannot bring out the egg or any one of the other individual ingredients as they are completely mixed together. Brazing is like icing the cake, it lays ontop and can be ground off or scraped off of the cake. What the members are trying to point out to you, heat, when metal changes temps it expands or contracts. You are still adding heat and causing the metal to change its internal chemical structure. If it returns to itself is dependent on many things that are not under your control or able to be seen with the naked eye. Good luck.
Good idea. I didn't even know such places existed for just regular people.
Tags |
braze, brazing, filing, handgun |
