Old 08-28-2011, 11:23 AM
This is reminding me of my little tractor engine swap: change one thing & you have to modify the next and that means the other will no longer fit so you have to build a different part.
I'm beginning to wonder how I will know when I'm done.
Old 08-28-2011, 12:13 PM
Just like new again nice job and great wrightup
Old 08-28-2011, 12:14 PM
Pyro J's Avatar
Pyro J Pyro J is offline
Hearts on Fire
Having the tractor start more reliably will be a real plus Dan. Hopefully that
carb rebuild helps with that.
Nice work on the bucket linkage rebuild.
Old 08-28-2011, 12:21 PM
CEC's Avatar
CEC CEC is offline
Over the Top
Dan,
I've been following your thread. Nice job on the repairs.
Glad to know everything is finally coming together.
Must be nice to have the tools and resources.
"There is one advantage to having nothing, it never needs repair. " - Frank A. Clark -
Old 08-29-2011, 07:50 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Cutter, that is the way all my equipment repairs go. I have found that knowing when to quit is a decision based on benefit vs time, if the repair now will save a lot of time later on then it is worth doing, but if the repair is not necessary to the item operation and can be easy done later then it is not worth doing.
Digr, thanks, I learned a lot from this repair.
John, Thanks. The tractor started easily yesterday, the carburetor rebuild was worth the time to do. The hard starting had been a puzzle for a while as usually this tractor starts easily at any temperature.
Chris, Thanks. Yes having the tools, material and the knowledge to be able to tackle this repair was nice. Having the know how of the members here to ask about things is a big plus also.
I put the bucket on yesterday, instead of making pins to mount the bucket I used 1" grade 5 bolts. I then started digging on the electrical service trench (post #22) again. The bucket does not slop around or get bound up like it used to do. All in all the repair was definitely worth it even if it took twice as long to do as I thought it would.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 08-29-2011, 08:12 AM
JohnBoy's Avatar
JohnBoy JohnBoy is online now
Director of Languages
Nice repair dan.
Any shots from a little further back. I'm not picturing where the bucket ram actually sits in this machine. is it inside the boom?
Old 08-29-2011, 08:58 AM
Lu47Dan's Avatar
Originally Posted by JohnBoy View Post
Nice repair dan.
John, yes it is inside the dipper stick, there is a relay bar that actually attaches to the bucket cams. The end of the cylinder rod has two rollers on it that run in tracks, the cylinder pushes or pulls the relay rod to move the bucket.
I really need to pressure wash and grease that assemble again.
Dan.
Hobart 175 Mig
Craftsman O/A set
Old 08-31-2011, 12:13 AM
Floptop's Avatar
Floptop Floptop is offline
A great thread Dan, thanks. I love the way you detail for us the "sub projects" involved in finishing your main projects.
