Picked up this lot tonight so expect lots of questions.
Going to be a while before I'm making chips because there's a list of house and yard projects ahead of it on the list, but I'll be tipping away at getting it setup in its new home over the coming weeks and months. The pillar drill ended up jumping in the van with it. The two motors look to be the originals from the lathe and drill and have been upgraded along the way. Best guess on the lathe is 1930s and the drill is 1987 I think |
Congrats! Hope the lathe works well for you!
Sent from my iPhone using Tapatalk |
Now there will have to be a monthly tooling budget established to keep her happy!!!
I think I need to up my measuring tools and maybe a toolpost but otherwise there's a lot of tooling in there to get me going. First job after I make a space for it in the shed is to quantify what came with it |
Like a kid at Christmas I've space made and everything but the bed unloaded from the van. Mrs is still in bed!
Fly cutter/4 carbide face milling thing 12mm carbide tools 3 carbide boring bars 5 end mills Er25mt2 chuck plus 16 collets Slitting saw Arbor Er30mt3? Chuck plus 8 collets 3 MT adapters Steady rest Inch mt3 drill chuck Half inch mt3 drill chuck Dozen taps and dies plus holders, thread gauges 9 change gears plus fitted ones Oil can Myford style milling table Blank faceplate 185mm 4 jaw faceplate chuck 220mm 3 jaw 130mm chuck 16 HSS tools 1 plain centre 2 live centres 1 4 tooth wood centre? 21 drill bits Handful of hand tools Small cantilever box Reamer? Adjustable square X/Y table for the drill What else do I need? I'm thinking centre drill, precision level and maybe a toolpost setup? What's that thing that's been hammered like a chisel on top but has a very non chisel other end? Can't see markings on the motor but it has two capacitors and a magnetic switch, plus the 15 amp plug and the size of it makes me think it'll do all this machine could need. |
Looks like a nice assortment of tools to get started! That mystery tool is puzzling. I guess it will probably end up being a punch to tap out whatever it fits for you. ![]() But the small end with the groove reminds me of a reamer type tool. Sent from my iPhone using Tapatalk
Never noticed that, technically that would be a gap bed, it just doesn’t have a removable section to fill in the gap. Could be handy for some types of work, or a pain for others.
What it may mean is real short jobs may need longer tools to reach. Sent from my iPhone using Tapatalk |
That lathe looks like a creampuff for its age!
![]() ![]() And those extras looks to be quite the haul! ![]()
Design to 0.001", measure to 1/32", cut with an axe, grind to fit.. ![]() |
Back in the day when that machine was made faceplates were much more commonly used than today so that might explain the wide gap. Still, I can't help but think that there should have been a gap piece in there. I can't see from the pictures but it looks like there is a locating pin and a couple of threaded holes in the gap. Would they not have been used to locate a gap piece?
Here's the Lathes.Co link to that brand. You have to scroll down a bit to see yours... http://www.lathes.co.uk/ehrlich/
