Old 11-26-2022, 05:27 PM
greywynd greywynd is online now
General preheating on the cutting edges up north is 250f before welding, interpass temps not to exceed 400f.
Ramp down is 50F at a time, with a half hour at each temp before dropping to the next temp.
Without knowing what material the original is, it does become more of a guessing game.
I would certainly do some after welding heat treat, even if it’s just in an oven/toaster oven. Wrap it in foil to minimize oxygen, (can even add a couple small strips of paper to let the oxygen burn off when they catch fire), and soak it overnight at 400F. Do a slow cool, 50F at a time the next day.
The transition at the edge of the old material and new will still be a mix of alloys, so could be hard from the original material. Be careful when you try to turn that on the lathe.
Old 12-30-2022, 08:34 PM
Well I made a new sprocket out of stainless and it will last until it doesn't.
ID:	166697   Click image for larger version
Old 12-30-2022, 10:04 PM
I suspect it will outlast both of us once again the "Real Deal" delivers
Old 12-30-2022, 10:30 PM
Scotts Scotts is offline
Well done and thank you for the posting of the drawing.
Old 01-01-2023, 07:49 AM
Nice job. Sorry I have not got an answer on the one i knew about for potential parts.
I’m sure that will work for a great while. Maybe have 60% less life expectancy before wearing out due to wear.
Thanks for the great drawing. I guess I never occurred to me that you would need to use two different end mills to cut the teeth, to get the ramp angles clearance right.
I think I made a gear once and I crudely filed/ ground in the secondary angle relief.
Old 01-01-2023, 02:36 PM
This was not the proper way to mill a sprocket, the only cutter I could find would only good for a nine tooth sprocket and the diameter was to large for such a small sprocket and was quite expensive. The two end mills worked perfect I just had to bevel the tips with a belt grinder.
