![]() It does have an additional motor attached to the back of the cross slide that I have never seen before. Searches haven't turned up any results although I'm probably not using the right search terms. At first I thought it was a tool post grinder, but it doesn't seem to be configured correctly for that. Any of you have any ideas??
I believe the appropriate metaphor here involves a river of excrement and a Native American water vessel without any means of propulsion. |
See allot of copper dust around it ?
Attachment is a commutator undercutter attachment. Used tiny little slitting saws approx 1" dia. |
The guy was a blacksmith for 70 years so it's unlikely he used it.
Those saws are way, way too big.
I think it will open up your world. Enjoy it.
What Doug said--an armature cutter. I got one with a similar lathe and sold it off as I didn't need it but somebody did...
I wonder if the armature cutter could be used for cutting small keyways?
For anyone interested, here's a link to all the pictures of what all comes with it: https://bennettauctionservice.proxib...ation/69163805 In would gladly take input on what all the little bits and baubles are there - I'm no machinist.
They’re not a bad little lathe, to keep costs down they used a lot of zinc (pot metal) for parts. Parts are generally available, though it may be through places like ebay etc from folks parting them out.
A little on the light side, so keep tools sharp and cuts light and they work well. Sent from my iPhone using Tapatalk |
In regular operation, your cutting the mica insulation from between the copper segments, and you doo cut a wee bit of the copper. As that motor is direct drive, cutting keyways in steel (if it did have the power & rigidity, which it does not by any means) is too fast for steel. |
