Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. The countries whom the gods would destroy they first make green. Rex Murphy Last edited by Ironman; 10-21-2021 at 09:39 AM. |
I put the 4 jaw back on the lathe. Seated the bar into the bore of the chuck and got it indicated in to .002 inch.
I then set the steady rest right in front of the chuck and adjusted the rollers to the point the bottom two just touched. Closed the top of the steady rest and adjusted the top roller. Opened the top on the rest and slid it into position and locked everything down. Checked run out at steady rest and had .003 inch. Fired up the lathe at about 350ish rpm and everything looks good. Tried top speed of 700 rpm but the rollers in the steady sound like it's too fast. Probably a little sore out. I think I'm good to go. Spindle bore is 1 3/4" iirc
Tim Self appointed director of junk, and old vehicles. |
Going to face off the end and drill a center and use the tail stock live center to do your machining?
Timmy the dumb fuck is at it again...
Read what Keith wrote, very rarely should run a steady on the mill surface. Mill stock is not round concentric or straight. Quote:
There is less run out in a Filipino Whore after the fleet sets sail.
Oh and clean that lathe up, it looks shitty and rusty.
You beat me to it.
By performing the operations in this order you establish an imaginary centre-line through the workpiece from the chuck to the tailstock centre. Unless you want to utilize some portion of the original OD of the material it doesn't matter at this stage if you have a bit of runout. Once you start machining all the surfaces that get turned are going to run concentric to that imaginary centre-line. This is why you can machine all the features on a workpiece and have everything running true even if your chuck has some runout. It's only if you have to flip a part in the chuck (to work on the opposite end) that you need to be concerned with the runout of your chuck. Once you've done all the machining on the OD of the part you can set up your steady if you need to perform drilling or boring operations on the end. If you have machined surfaces on the OD of the stock you can run the steady there or you can cut a steady band just for that purpose. You would try to place the steady a lot closer to the end of the workpiece than Tim has in his pictures...
Or run a cat’s head on the part. Don’t have a pic but should show up with a little digging. Sent from my iPhone using Tapatalk |
Some progress. Punch fits nicely in the bore.
Lathe isn't rusty, camera makes it look bad.
