#1591
![]() Yesterday I went and prepped the mill to be loaded out and moved. It's mostly ready to go. I'd like to keep the arbor mounted to the husk frame but that would take up a lot of trailer space that way. But would make putting it back together easier. As far as dismantling is left...that would leave: Removing the 4-71 from its mounting base. It's on a sliding frame to tighten the drive belt. Remove the husk frame from its support over the sawdust pit. Spilt and remove sawdust chain and supports. Remove saw blade from arbor. The carriage is from a Frick size 0 sawmill. It's two welded together. Five head blocks and 6 axles. It's about 20 feet overall. The husk frame is the base to some other machine made by the F.L. Estes Mfg Company in Nashville TN. The track length is about 73 feet and there are extra rails that go with it. https://youtu.be/_TNjkFuIqfs Bethlehem steel track.
Tim Self appointed director of junk, and old vehicles. |
#1592
One things for sure.
Tims not scared! don't get hurt. |
#1593
The iron for that steel likely came from a mine just east of where I was in Onterrible.
https://www.marmorahistory.ca/the-mi...armoraton-mine Sent from my iPhone using Tapatalk |
#1594
If you are going to set up the mill, the foundation should be frost prof and adjustable. That means every time there is a wide temperature swing, such as winter to summer, all alignments must be checked and reset. The track and husk must have the same treatment. If there is misalignment you will be cutting long wedges or clapboard siding. It isn't hard to do, but without a good foundation you'll feel you're just chasing your tail.
Make over, make do, or do without Why do I have to press one for English when you're just gonna transfer me to someone I can't understand anyway? Grant me the strength to accept the things I cannot change, the courage to change the things I can & the friends to post my bail when I finally snap! |
#1595
First load of sawmill machinery halfway home.
#1596
Your neighbors are going to LOOOVVVEEE you!
#1597
How close is your nearest neighbor?
#1598
Nearest neighbor is about 400 feet away. But there's a heavily wooded stand of trees and brush and a valley between us.
I plan to add a muffler to the Detroit. Doubtful I'll run the mill more then a couple times a month. If need be I'll build a shed to house the engine and cut down on noise.
#1599
what brand is the red engine?
and keeping a 71 quiet is a big job! |
#1600
Tips on starting a Detroit that's sat a while?
