same reason I spend the extra for Miller Welders... (or Nikon Cameras ![]() I know they will work first time EVERY time... now... this year... next year...and many years to come... for me.. that peace if mind is worth the extra freight.. ![]()
. . Pay no attention to that man behind the curtain.. ![]() The more you Know, The Better you Know, How little you Know (old Estonian saying) Last edited by H80N; 05-08-2013 at 02:53 PM. |
I think we are all in agreement, i'll throw my thoughts in as well.
I can not see if an electrical circuit is live or not looking at it. It looks the same on or off if there is no light or something associated with it. Like the position of a breaker or disconnect handle. Even those can and do go bad and fool you. Therefore I trust my life with the quality of my equipment. Electrical test equipment in this case. You decide your level of comfort with your equipment. Even then the back of a hand goes first. ![]() Scott |
Excellent advice....!!!
much better to slap yourself with a backhand from involuntary contraction than a deathgrip and electrocution from an unexpected hot circuit... ![]()
. . Pay no attention to that man behind the curtain.. ![]() The more you Know, The Better you Know, How little you Know (old Estonian saying) |
An ammeter won't tell you a circuit is live, only if current is flowing.
Scott |
Fluke also and get a non contact voltage detector as well then use it.
as a life time electrical guy I have never taken a chance on whether a wire is live. Before I work on anything I want to know what the voltage and current limits are.
Life beats the alternative hands down. |
Fluke is the inly way to go. I recommend a Fluke 337. I have had mine for 3+ years. I own several other fluke meters are well, but since purchasing the 337 I haven't really touched the others....
Always assume a circuit is live. Always work on a circuit as if it is live and you will live to talk about it. ![]() Meters, voltage detectors, disconnects, etc all can and do fail (as someone else here already mentioned)
Chris in Maine |
Looks like there is a recall for some of the FLUKE 337.
http://www.fluke.com/fluke/usen/Supp...trck=33xrecall
=== Some things to consider. I'm not a big fan of large clamp jaws, they will not get into a tight spot. You are asking about peak hold, definitely a nice feature and a must have. But in your case you will more then likely need one with a delay or a timed update sample, that is if there is one on the market. when you first start the arc you are likely to draw well over 200 amps for a few milliseconds a peak hold meter will likely hold/display the high surge amps and not the welding amps after the surge. The Data hold will lock the display but you will have to push the button while you are welding. TRMS is a good idea. Old AC meters are calibrated at a fixed 60 cycles (the line frequency). Newer electronics chop up the 60 cycle frequency into some other frequency other-than 60 cycles, non TRMS meters may not display an accurate reading. Example: 60 cycles (60 times a second), AC is the standard house current. Say you have a desk lamp, you start turning/cycling the power switch On and Off continuously nonstop. the cycling of the switch alters the frequency at a rate of speed you cycle On/Off.. Modern electronics do the same, inverter welders..., switching the power at different speeds and random....., meters may not display a correct reading. True RMS meters operate in a broader frequency range then the fixed 60 cycles giving a more accurate reading on modern electronics.
Here is something really cool - the AEMC 407. 1000 point recording capability, with wireless PC interface for $450. You can set it record every second, to every 10 minutes. I've not seen one, just read about it on Amazon.
You might be able to do something similar with a wireless fluke and a PC. I don't see any Flukes with onboard recording. Not trying to say bad things about Fluke. I love Fluke equipment. Just saying you can get more features for less money. All depends on your needs. |
