The definition of courage. "It's when you know you're licked before you begin, but you begin anyway and you see it through to the end no matter what." From "To Kill a Mockingbird" |
When I use my transfer punches I paint the part and just use the punch to mark the paint. Then I get a regular center punch to make my dent.
Well I did this last Thursday night. Pulled the manifold and turbo off, practiced on the two easy to reach broken bolts, and then on to the hard ones. Because of the oil cooler line being in the way, I ended up having to use a right angle air drill with a cut off bit to protrude 1/8" to get them started, then make it a little longer. I used a dremel carbide point in the drill to center start a few of the bolts. They all came out really easy, I used a Sprayway black label penetrant, worked great.
I pulled the tractor into the shop around 5 pm, started pulling stuff off, letting it cool, had supper, changed the hydraulic cooler/intercooler out (oil leak), fixed the crankcase vent to where it wouldn't be so messy, and did the manifold bolts and got through around 1 am. Nothing was hard, it just took time. Thanks for the tips. |
That is good news what will you do for an encore?
Life beats the alternative hands down. |
Did you use anti seize this round?
![]() ![]() Glad to hear it went smoothly, drilling out broken bolts can be a PITA. A couple times when they started off centre I've been able to use a die grinder to grind down the thicker chunk (Haven't got drilled right out to size at that point, so threads in the hole are okay) Go until you just see the 'tips' of the threads are showing, then you can usually peel them out with a chisel or something. |
Yes, I sure did use AS this time. I had to drill one at an angle to be able to reach it, and when I got the nub out I saw that I had drilled just far enough where the first thread of the bolt was gone. I got pretty lucky on that one. Broke one bit ( it was a cheap one, grrr, actually broke in 2 places), but it was down deep enough, where I could cut down an extractor and still get a bite on that bolt.
Congrats. I am glad the job went well with no bad times.
Would it be a bad idea to just replace them all once a year as a preventative measure? Or are they just gonna break on me when I try to back them out?
If they came out fairly easy and you used NS you should have no problem getting them out after a year.
At least replace the hard to drill out ones and remove and re never sieze the others for your own piece of mind/
Well I had to do the exhaust manifold bolts again, Two of the old ones broke again. This time it was the front 2. It was pretty simple this time, me and my helper did it in less than 4 hours. Most of the time is in taking parts off and putting them back on. Put the new style bolts on it, see if that will help. I used a torque wrench this time, maybe that will help too. I also noticed the manifold isn't real straight. Maybe an 1/8 of an inch bow outward to both ends. Time will tell how long these last, the last time only 1000 hrs....
