Old 03-30-2019, 04:35 PM
gimpyrobb's Avatar
gimpyrobb gimpyrobb is online now
Default loose socket
So I used a speed wrench at work for 90% of my job. Another tech borrowed it and lost it. I gathered up the needed parts to replace it and assembled the parts. Everything works great EXCEPT for the extension. The socket used was an impact socket and I should have known better, but I needed to get to work.
Whats the best way to snug up the joint?
I cant weld it cause I need to separate the joint to fit in the toolbox after my shift. I'm thinking of adding a weld bead and file flat(on 3 sides) or maybe drill and tap for a set screw. What do you guys think?
Old 03-30-2019, 04:47 PM
A little spray paint inside the square hole and it should fit tighter.
Harry S. Truman
Old 03-30-2019, 05:12 PM
gimpyrobb's Avatar
Nah, paint wont be enough, too much slop in the joint. I may just be better off cutting off the clapped out impact socket and welding another on.
Ill try to post a pic after I start my shift tonight.
Old 03-30-2019, 06:32 PM
gimpyrobb's Avatar
At the end of the ext, there is 3-4 inches of travel.
Old 03-30-2019, 06:37 PM
Cut it off and weld another proper fitting socket on it, or drill it and push pin it.
Old 03-30-2019, 08:58 PM
I might have a suggestion if I understood what you are talking about. Am I the only one who doesn't get it here?
Old 03-30-2019, 09:18 PM
...Am I the only one who doesn't get it here?
Nope...
Old 03-30-2019, 09:31 PM
gimpyrobb's Avatar
Too much slop in the joint where the ext meets the speed wrench, not sure how thats confusing.
Anyhoo, I tried some shim stock and its better, not sure how to keep it there though.
Looks like I'll have to drill and tap it for a set screw or two.
Old 03-30-2019, 09:47 PM
digr digr is online now
Just do what wolf said cut it off and weld on good end on
Old 03-30-2019, 10:05 PM
Scotts Scotts is offline
Harbor freight has extension with a locking end to hold sockets on. Here
The socket is held on the extension and when you want it off slip the ring back and it comes off.
