Old 02-28-2019, 03:21 PM
Default Swivel Base for Parker 985 Vise
I'm not sure if the swivel mount that I wish to make or this vise should be highlighted in this thread as I find both quite kewl.
This style vise with the large diameter screw and built in anvil is called a "service vise". It looks as Parker called this line of service vise (or vice as y'all from the UK spell it) "Big Bear". It was available in a 4" jaw model 984 or 5" jaw model 985. They could be had with or without a swivel base. At 102 lbs. I consider the 985 vise as entering the big vise category. It is in what I would consider extraordinarily good condition, especially for one this large as the bigger ones seem to get beat on more often.
This is a filler project as I have two others going on at this time. I hope this thread will help to keep me motivated to finish it sooner than later.
Old 02-28-2019, 03:29 PM
Parkers are splendid vises, made with fine attention to detail compared to most.
Old 02-28-2019, 05:20 PM
Spencer Spencer is offline
I can't get my swivel base to lock tight enough not to rotate when I'm doing any serious work with it. I've actually considered trying to weld it in a stationary position, but I know that would be a crime.
I've somehow tightened the locking handle down tight enough that I can't easily get it loose. One of these days I'm going to have to take the whole thing apart and see what can be done to improve it.
Old 03-01-2019, 12:51 PM
The drawing shows the footprint of the vise in bold line. The light lines show my intention for the swivel base. I have started by trimming off most of the unwanted material from a 1" thick steel plate. I used a horizontal band saw to do this. The rest of the machine work will be done on the rotary table and milling machine.
Old 03-01-2019, 12:55 PM
A view from the other side. I can spot a Parker from forty feet. They have unusually shaped jaws that form a radius when close together. This is ideal for high clamping pressure while providing clearance for your hands.
Old 03-01-2019, 10:39 PM
Geez, don't weld it.
Take the locking bolt handles off and remove the bolt/nut combo from the base. Mark the spots on the table through the swivel base, drill and bolt right through to the bottom of the table.
Now you can reef on it.
Aaron Neville
Old 03-01-2019, 10:41 PM
I knew a guy who had the same problem. He welded 8 spots inside the swivel base on the upper and lower side with nickle rod so the vise could be moved around and then locked in by the spot welds, so the stress from twisting was contained by the spot welds instead of the friction of the bases.
Old 03-01-2019, 11:05 PM
Camaro Zach's Avatar
This is what I did with my vise.
I don't really understand the need for a swivel base.
Buggy
Old 03-01-2019, 11:22 PM
I have one with a swivel base and the jaws also swivel. Very handy to rotate the jaws and clamp something vertically.
Old 03-03-2019, 12:02 AM
It depends on what you use the vise for and what may be in close proximity to it. My shop often has many objects in and around my work area. There have been numerous times where a swivel vise allowed me to clamp on to an odd shaped or long work piece. In these situations I was able to rotate the vise so I could clear objects on a workbench or the workbench itself. I may have had a vehicle or a machine next to the vise that would have otherwise interfered with an extra long object I wanted to clamp. When forming rod, bar and such a swivel vise will allow one to position the work so a full swing can be made while the iron is hot.
