  #41
Old 03-23-2018, 08:47 AM
RED caddy's Avatar
Da Chief
Thanks, I get it . I always thought of a "back up ring" as a radial split ring kind of thing that fit the ID/inside the "O" ring to tighten it in the bore.(used when I cut the groove too deep, LOL)
Thanks, Paul
  #42
Old 03-23-2018, 11:25 AM
Norm W's Avatar
Norm W Norm W is offline
https://ncalculators.com/area-volume...calculator.htm
This will tell you the diameter/radius of the piton needed for a direct read on the gauge or what ever multiple you want. For example a radius of .564 gives you a .9997 square inch piston. That should give you a close direct read on a gauge.
  #43
Old 03-28-2019, 08:09 PM
Red did you ever get this done?
  #44
Old 03-28-2019, 11:09 PM
By the way, a brake wheel cylinder cup would make a good high pressure seal.
You want a friend in Washington? Get a dog.
Harry S. Truman
  #45
Old 03-29-2019, 07:30 AM
Oh yea and this having to open up the pressure cyl. to see the dia is silly. Just measure the pressure for a KNOWN weight on it and (what is that expression,? "Bob's your Uncle") :-)
...lew...
