Old 04-10-2019, 03:23 PM
Also, the sprocket arrangement gives you the ability to change gear reduction fairly cheap. That way if the motor is marginal you can just take a deeper reduction.
Old 04-11-2019, 07:33 AM
I find good used speed reducers at the scrap yard on a regular basis. Some of the them have motors attached or the motor will be in an adjoining pile. I have bought many for less than $0.20 per lb.Perhaps you could find something suitable too.
Old 04-11-2019, 07:38 AM
Or if the reduction of the reducer is not to your liking you can arrange that with sprockets too.
Old 04-11-2019, 12:19 PM
Dr Dean's Avatar
Dr Dean Dr Dean is offline
no bull it's huge!
I can't say anything about how much torque you will need but what I can tell you is this is a good place to use even if you don't buy from them. I get all kinds of ideas on better ways to do things when I see what's available. They also have some good reference material on the web site. https://www.surpluscenter.com/
Old 04-12-2019, 07:19 AM
chumly2071's Avatar
Urban Gunfighter
If I ever get around to powering mine, I'm going to use the HF pipe threader, and get the adapter and shaft parts from swag off road. The hub is like $35. I'd use it 5o power both my head and tubing rollers.
Sent from my SM-G920V using ShopFloorTalk mobile app
Old 04-13-2019, 07:20 PM
60W is less than 1/10 HP, 120W is about .16 HP so I'd go with the latter. Our bead roller isn't powered so I don't know how much actual HP it would take but it can require quite a bit of force if you have it turned down fairly tight in thicker material. You've got significant reduction in that gearbox so you should be all right...
Here are the specs I found for one factory conversion kit id like something gear motor wise to be same or a bit torquier I just don't know much on searching eBay for this and not opposed to a used motor either
Motor: 1/6 HP 1.65 Amp
Gear Reduction: 75:1
Toggle Switch: 3 Position
Infinite Speed Adjustment: 0 – 20 RPM (11.8FPM)
Speed Control Knob: Infinitely Variable
Wolfie,
.16 HP is right at 1/6 HP. You should be good to go if the conversion kit is not underpowered.
