Old 03-20-2019, 06:31 AM
Bubba's Avatar
Bubba Bubba is offline
Default Worm Gear lube question.
I have a "Professional" Kitchenaid mixer.
The worm gear drive is toast.
The grease was used separated into a black mess
and light oil that oozed out everywhere at the
seams of the body. The chamber the gear runs in
is not sealed so I don't think I can use oil.
What kind of lube can I use that do not separate?
Nuke em til they glow then shoot em in the dark.
Old 03-20-2019, 07:20 AM
I would use Fluid Film. It is food safe and stays where you put it but won't get hard like that yak fat they put in there. spray it on and it forms a light grease. That hard grease is the same shit they put in angle grinder gearboxes.
Aaron Neville
Old 03-20-2019, 10:10 AM
I had the same problem I went to the local oil supplier and bought "food grade grease" and the mixer has been fine since. I think I still have the tube, I will look later.
Old 03-21-2019, 11:50 AM
https://www.amazon.com/Kitchenaid-W4.../dp/B00OSC174E
https://www.mcmaster.com/1378k31
The silica thickened grease from McMaster should last the longest.
Old 03-25-2019, 06:41 AM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
Angry
Bubba, there is supposed to be a gasket in there, I rebuilt my 5quart pro model, and it had a gasket. I picked up a broken 6quart pro model last fall when I helped a friend clean out her aunts house to get it ready for the estate auction, it has a gasket also. It needs a good cleaning and a new gear train.
Just remember not to overfill the transmission housing with grease, too much is almost as bad as not enough.
Dan.
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 03-25-2019, 07:03 AM
I would use Fluid Film. It is food safe and...
Sorry Gerry, no it is not.
Dan.
2/3 of the volume should be filled with grease, 1/3 air.
