![]() Sent from my iPhone using SFT
Dylan "There are three kinds of men: The ones that learn by reading. The few who learn by observation. The rest of them have to pee on the electric fence." |
Are you spindles offset from the axle tube or is the tube "pre-stressed"
aka bent. If not just rotate the axle tube 180 degrees.
Shade "Prepare to defend yourselves." -- Sergeant Major Basil L. Plumley, Ia Drang Valley Last edited by Shade Tree Welder; 05-28-2012 at 05:22 PM. |
I can't remember if it's off set or not. Lol. But yes it does have a camber in it.
The plate you mention might just be part of the u-bolts and not welded
on. Hard to tell with out looking at it.
I have done this about 3 years ago . The axle were in fact pre stressed ( bent ) after cutting the plates off , i lined them up on the other side of the axle by bolting them back to the axle . them tack welding them . Droped em down a bit . then welded them up with 7018 ,s No ill effects and worked fine .
After all is said and done ,, more is said than done . |
I'll have to look that there welded but I'm pretty sure they are. I was not planning to cut the old ones off figured it would make it easier to line the new ones up. I'm talking about the plate that the springs sit on in between the axle.
The plate I'm talking about are these. Sent from my iPhone using SFT
By bolting it all to the axle was the easy way to be sure everyting was lined up before final welding . yup thats the plates . they were welded to the axle on the one i did . What Shade Tree Welder suggested was what i planned on doing until i seen the axle had a bow in it .
It's best to have the axle sitting under the spring anyway, so the U-bolts don't have to carry the load. Any trailer parts store will have new spring perches for probably less money than the cost of steel to make your own. Might even get them from NAPA.
"The trouble with having an open mind, of course, is that people will insist on coming along and trying to put things in it." “The thing about quotes on the internet is you cannot confirm their validity” Abraham Lincoln |
They are called spring seats, and yes the best thing would be to add new ones to opposite side of axle and U-bolt back on.
If you find yourself in a hole, the first thing to do is stop diggin'. |
You could install some taller equalizers..
