Old 11-19-2022, 11:14 PM
OldRedFord's Avatar
Kibble King
First, your outer races, note I used plural not singular, you have 2 races, not
a single race, so your wrong.
Second, while the welding method above will work, I would just support the
pulley/wheel on some wood blocks and use a drift to tap the 2 outer races
out of the pulley. What you think is a worn area is just and inconsistency in
the casting.
Third, the welding method is best done with a TIG welder, just run a bead
around the inside of the race, no filler metal is needed. It works by heating
the race up while it is constrained in the pulley, that cause the races to
expand in the direction of the shaft that would be there, because it cannot
expend in the radial direction, then as it cools it contracts in the radial
direction, and loosens in the bore. Principle of constrained expansion and
unconstrained contraction.
Looks like the rusty ring in the center is the middle of the outer bearing race. Tried heat and a 20 ton press to get the race out and it didn't budge.
I'll try the welding trick.
Tim
Old 11-20-2022, 06:27 AM
Default Bearing help
Heat will expand both the hub and race, and the race being a thinner cross section, it will expand more, due to more heat absorbtion.
Try the press again now that it’s all cooled off again.
And make sure you are only pressing against the bearing race. You may even have to turn a slug the correct size on the lathe to do so.
Old 11-20-2022, 08:58 AM
Are you sure the "rusty ring" is not the seat for the race?
Old 11-20-2022, 02:49 PM
Still seems to be some confusion about the bearings Tim is dealing with. What he has is two ordinary tapered roller bearing assemblies--one cone (or inner race) and one cup (or outer race) per assembly. The inner race (shown in the first picture he posted) is a bit unusual in that it has an extended hub but otherwise it's no different than any other cone. The outer races are typical of ordinary tapered roller bearings. There are two of them pressed into the hub of the pulley from opposite sides. The rusty section in the middle is part of the hub or pulley, not part of the bearing, it's the back of the pocket the race sits in. Those races have to come out from opposite sides, you cannot push them both out from one side. The easiest way to do that is to run that bead of weld around the inside. A press is of no use in removing them...
Old 11-20-2022, 03:26 PM
That rusty ring is actually part of the pulley not the bearing but Timmy is not
listening. So when he breaks the pulley he will be really upset for not paying
attention again. He thinks it is a single race and it is not it is 2 outer races one
needs to come out in either direction from the hub. I just have my popcorn
here enjoying the shit show.
Old 11-20-2022, 03:31 PM
Oh your right, but this is too entertaining I want to see the pulley busted up...
I have had good luck with a slide hammer or like I said a hammer and a drift
can remove them. But as you said, and I said... One out each side, as they
are separate pieces... But Timmy know better and thinks it one piece. But I
don't even want to start on how a pulley would walk off a one piece outer race
if it was really the way he thinks it is...
Old 11-20-2022, 03:32 PM
What are they odds he welds the races to the pulley? I say 1:2!!!
Old 11-20-2022, 03:53 PM
astronut's Avatar
astronut astronut is offline
Bring on the entertaiment!
Still got the shovel!
Lincoln Weld Pak 100
Giant Tech Arc 200
Miller Roughneck2E
Old 11-20-2022, 08:49 PM
OldRedFord's Avatar
Kibble King
I've never come across a setup with two roller bearings and two separate outer races that can't be pressed back out. Every time I've seen two taper rollers....the outer race was one piece.
I tried the weld and no luck.
Tim
Old 11-20-2022, 08:55 PM
Hey shit for brains!
You have 2 outer races, they need to be driven out in opposite directions,
until you do that you will not get anywhere. Oh and what you have 'seen'
is not common in the real world.
