Old 10-07-2022, 06:51 PM
JBFab JBFab is offline
Default Aluminum surface finish
Working on a little project with a lot of flat surfaces. Mostly 1/8 6061 with a bunch of welding. I'm doing my best not to scratch it up too bad while I'm working on it, but thinking about how I'm going to finish it when I'm done.
I had thought about picking up a burnisher from horrible fright, but was also thinking about using a Scotch Brite pad on my RO sander. Any thoughts?
Sent from my SM-S908U using Tapatalk
Old 10-07-2022, 07:12 PM
Depends on what type of look you are going for. Once you start scratching it with anything, you will be committed to doing the whole piece to make it look uniform. It’s really a pain when you want a polished mirror finish.
A RO sander will leave a pretty good scratched finished.
One trick I’ve learned with aluminum and sandpaper, is to have a wax candle and use it on the pad. It helps to not load up the paper. Works really good on grinder sander pads for preparing the ends.
Old 10-07-2022, 08:07 PM
Surface finish isn't real important. Just looking for uniform without a lot of effort.
I use Irish Spring on my abrasives. Smells great!
Old 10-08-2022, 02:02 AM
Do I have a life?
and the lassies love it!
How about a maroon scotchbrite pad on a longer sanding block and lightly draw it in one direction over the surface?
HF 80 lunchbox w/tig
Old 10-08-2022, 07:15 AM
Norton version, I have used this with great results for a brushed finish, use it
in a variable speed grinder and you and keep the heat to a minimum.
https://www.nortonabrasives.com/en-u...rbor-hole-disc
Old 10-09-2022, 07:52 AM
That was my first thought. I'll have to try some.e of the suggestions here.
