![]() Years ago Terry Lingle gave me some Enerpac 3" stroke 10 ton cylinders. I made a puller out of one and then nigger rigged a addition to it because it started to be too small. I found I was bending the all-thread in a lot of cases to get the rods into the slots, because the arms were too short. This year is the time to do it properly. And I'm trying to finish off a few half done projects before the 24th ![]() So the Milwaukee metal saw cut of a fresh chunk of steel 12" x 4" x 1" And I drilled a 2" hole in the middle. The threads on the cylinders are 14tpi and it needs a hole 2.17 to begin threading. Did the lathe work yesterday and today I cut the slots for the pulling rods, and then faced it off. There is a picture of the little one and today's job.
Gerry the tool maker! Very nice work.
Someday I want to modify a stubby 20ton jack for this sort of thing. Years ago I recall doing heavy pulling with a hydraulic jack on its side and chains in a slotted plate. A terribly funky setup that had to have 5 arms and hands to set it up until it got tight.
That's almost to pretty to use
Drawing by Smartdraw |
Nice.
Sent from my iPod touch using ShopFloorTalk
I think I posted a thread about it here. ![]()
cutter Housekeeping Staff: the Gatekeeper Director of Policy, Syntax and Grammar (by appointment) "Dr. Chandran, will I dream?" Just Keep Walking "I am not a body, I am free. For I am still as God created me." |
Yes, I recall that on your website.
![]() A part of me wanted to get fancy and taper the arms away from the cylinder, and then I got to thinking about how the further out on the arm how much greater the force is, and decided that'll do as is.
I just occurred to me that I made the flycutter I used on this project on the the little mill I sold to KevinF
A tool to make a tool. ![]()
Forgot one- A tool to make a tool to make a tool. ![]() Sent from my iPhone using ShopFloorTalk
