Old 04-11-2018, 10:08 PM
Not to derail the thread, but that's an interesting concept.
We use letter based revs prior to release to the shop. Once all the signatures are collected, especially the customer's, we go "yellow", Rev 0 and print on yellow paper. Later revs are numeric.
Back to the topic at hand.
I've seen them done both ways. Whichever way it is done, it is important to maintain the same process.
Old 04-12-2018, 12:27 AM
I didn't really understand your problem with the cutters and the base. Here is the stand I will make if I ever need one.
Old 04-12-2018, 08:24 AM
Scratch Scratch is offline
You guys and your fancy mag drills making me want to go buy one even though I only have one job for one...
By the way if anyone with one lives near Western Wisconsin and wants to rent it out for a day, let me know! I need to drill some holes in my welding table.
Old 04-12-2018, 08:25 AM
Ironman Ironman is online now
Had a need to use the mag drill today to drill a 3/4" hole in 1/2" plate. With the riser the mad drill sits on, it is too high for using the annular cutters for small parts down on the extended base. With the drill chuck adapter I made some time ago, it works well since the adapter and drill chuck length is just right to drill parts on the extended base.
Did you add in this riser? It does not seem normal to not be able to use annular cutters.
Old 04-12-2018, 09:29 AM
Yes, when I did regular drawing work, we just used letters.
Got into buildings and such work, with large contracts, and subs.
They said, use numbers (for any changes) after the drawings are handed out (for bid).
When the job is awarded, we strip all revision blocks, issue the set as "new".
Then, as the job is progressing, any changes are released with letter revisions.
Old 04-12-2018, 10:03 PM
The reason for this new riser is to use a annular slug cutter for a small part without taking the mag drill off the "orange" base. When I want to use standard drill with a Jacobs chuck for a small part, no riser is required since the adapter and the Jacobs chuck reach down to the "orange" base. The hole in the 1/2" plate I wanted to be a little more precise, since the hole would be used for an arbor in the lathe.
Old 04-19-2018, 11:48 AM
Drill a couple holes, tack bolts into the 4” going down through your base, and a couple wingnuts and it’s be quick to take on and off, and no c-clamps required for that part.
R1 done. It was good advice. Thanks.
Looks good!!! You have room for three more cans on the table.
I am in process today clearing off all the spray cans.
The problem was with the adapter for the drill chuck and the extra length of the drill bits. My base is about the same height as yours, just a little different in shape. I made the base primarily to use a standard drill chuck to adjust for the extra length of the drill chuck, longer drills and the adapter. When I use the jig it is only for using the annular cutters, which are shorter, because the stroke on my mag drill is not long enough to reach the base extension.
Old 04-19-2018, 12:20 PM
With these stands/bases, are you just using the magnet to hold it in place or do you add extra hold downs of some sort?
Old 04-19-2018, 06:31 PM
The base is bolted to the bench. The jig is bolted to the base.
