  #41
Old 01-20-2019, 07:58 AM
arcflash arcflash is offline
I see a trend here. Great idea! A little extra weight on that rake from the wheels didn't hurt either.
  #42
Old 01-20-2019, 02:17 PM
They don't go flat...however, they stick really bad when frozen.....
  #43
Old 01-20-2019, 02:34 PM
Not too likely I will be dragging the driveway or chipping brush when the ground is frozen.
  #44
Old 01-20-2019, 07:13 PM
Finished up the chipper/shredder wheel project today. Had to buy 4 shaft collars for $5. Everything else was from the resource piles. Now have two new rubber tires for something else.
Used rust reformer as a primer and old yeller for the final coat. Baked the paint on top of the wood stove for an hour.
ID:	148984   Click image for larger version
ID:	148985   Click image for larger version
ID:	148986   Click image for larger version
ID:	148987   Click image for larger version
  #45
Old 01-20-2019, 10:13 PM
They look pretty good there Chris...
  #46
Old 01-21-2019, 02:25 PM
Thanks. Pretty is not a real big thing to me. Functional is usually all I am after.
  #47
Old 01-21-2019, 03:13 PM
Me too, until 6 months down the road, then wish I had taken that little bit more time to make it look nice.
  #48
Old 01-21-2019, 09:57 PM
I'm that way with almost any "finishing" be it paint/varnish, or even wiping off the layout ink. Later I sort of wish I'd have done a bit at least. :-)
...lew...
  #49
Old 07-29-2020, 04:29 PM
Last couple times I used it the wheels were mighty sticky even though I greased the axles every couple years. So an upgrade seemed appropriate. Drilled a 5/8" hole in the outer surface of the wheel so a grease gun hose would fit in the hole. Then drilled a hole in the hub and tapped for 1/4-20 zerk. Took an hour to do everything. Greased it up and it spins with one finger now.
ID:	157090   Click image for larger version
  #50
Old 07-30-2020, 06:31 AM
I have this on my grease gun:
https://megadepot.com/product/lumax-...19bbdec3b4209b
Set at 90 degrees, I'll bet it would fit in there without the hole in the rim.
I find the attachment very handy, and it doesn't seem to get in the way.
