Old 10-27-2020, 09:09 AM
I rough cut much of the shaft with a carbide cutter had from the scrap yard. This cutter has a shank diameter of 16mm but held with a 5/8” collet.
I also attached an end support bracket with a 3/8 screw into the previously threaded hole on the end. This was necessary to prevent the shaft from rotating when milling.
The extra length of the new shaft was to provide a heat sink to reduce the amount of heat conducted into the motor.
Old 10-27-2020, 09:14 AM
The milling is done. The last .040” will be done with a stationary tool.
Old 10-27-2020, 09:17 AM
But first I must cut the excess shaft. Nothing like a bit of exercise first thing in the morning. Can you guess where I got this hack saw from?
Old 10-27-2020, 09:20 AM
Get the hacksaw from the scrap yard? Or as I like to call it, the recycling yard.
Old 10-27-2020, 09:24 AM
Checking the alignments before the turning operation. It was good to see almost no change.
I only have 3/4” of indicator travel so I made extra certain it was as close as I could get.
This is where I left it. I will now make the electrical circuit for the turning operation.
Old 10-27-2020, 11:43 AM
Default shaft modification
instead of using a grinding wheel on the angle grinder, use a rubber backup pad and a 80grit sanding pad to get it close..for a much nicer surface finish..then full shaft rpm and a cloth sanding belt or strip pulled back and forth along the length by hand..FWIW
Mig, Tig, Saw, Heat, Plasma, Turn, Bend, Grind and Blast
Lift, Load, Push, Compress, Generate, Illuminate + Elevate
Old 10-28-2020, 02:21 PM
I’m assuming you either didn’t read the earlier posts or you misunderstand my objective. The sole reason I bought this motor is to see if a shaft could be added without disassembly using the milling machine for the process. Or maybe I misunderstand what you are referring to.
I get what you mean about the grinder. A hard wheel does not like to travel over uneven surfaces. A rubber or foam pad under a flexible grinding disk is better.
Old 10-28-2020, 08:57 PM
Ironman Ironman is online now
Originally Posted by threepiece View Post
I’m assuming you either didn’t read the earlier posts or you misunderstand my objective. The sole reason I bought this motor is to see if a shaft could be added without disassembly using the milling machine for the process. .
Looks like you got'er done to me.
Old 10-29-2020, 12:27 PM
seagiant's Avatar
seagiant seagiant is offline
Hi,
Looks good, I would not of done it that way, but...
I would of machined a step on the shaft stub and then a peice of steel to fit that, with just enough room to pre solder (tin?) those together...
Then would of drilled a 1/8" inch hole through the middle and peened a peice of drill rod to mechanically lock it.
That would of kept the heat down, protecting the bearings and the new shaft would be auto aligned, so to speak!
I worked Merchant Ships and sometimes you have to get creative to fix things, but that was the fun part to me.
At the end of the day, it is whatever gets you to the Dock!
“If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace.
We ask not your counsels or arms.
Crouch down and lick the hands which feed you.
May your chains set lightly upon you, and may posterity forget that ye were our countrymen.” -Samuel Adams
Old 10-29-2020, 11:58 PM
The turning worked out reasonably well. I used a 3/4” boring bar in the machine spindle. The backlash in the gears caused a bit of trouble.
I used a typical light switch to somewhat regulate the speed. After switching off, I advanced the tool as the motor slowed. It was strange operating the mill without it running, I repeatedly reached up to the spindle control switch till the very end.
