  #151
Old 10-07-2024, 05:07 PM
CaddmannQ's Avatar
After dinkin’ around with aquariums for 3 days, I finally got the other side patched. There is a lot of torch repositioning to weld this crazy patch.
I also got the reinforcements on and hook welded down and it came out OK. Not beautiful Internet art welding, but a step up from farm hand stick welding.
ID:	171895   Click image for larger version
  #152
Old 10-09-2024, 04:12 PM
CaddmannQ's Avatar
Woohoo! I have trimmed the patches, and tacked in the little frame closures, the big connector/gussets, the doubled pan corner reinforcements, cast hooks, and subframe hangers.
ID:	171900   Click image for larger version
  #153
Old 10-09-2024, 04:41 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
Have you considered something like this for sealer?
https://www.amazon.com/gp/aw/d/B0CSD...6-662902b7d803
Live like you are dying......because you are.
  #154
Old 10-09-2024, 06:32 PM
CaddmannQ's Avatar
I wasn’t going to undercoat. Just paint and seal joints & seams.
  #155
Old 10-14-2024, 09:54 AM
CaddmannQ's Avatar
It was too breezy to do any more welding, and I decided I would put some “speed holes” in, to lighten my huge gussets.
There were two unnecessary slots in one gusset, and this would make them match.
I was just starting the second one when my hole saw decided to croak. I sharpened it, but that was wasted effort.
It has lost temper and is useless for cutting even this mild steel.
I should have done this on the drill press before welding. I could cut the welds and use my flycutter, but I decided to do it the hard way.
Drilling a hundred little holes, bust it loose, then grind smooth.
I want to do this to the two subframe hangers, but not without a better hole saw.
ID:	171912   Click image for larger version
ID:	171913   Click image for larger version
  #156
Old 10-14-2024, 02:36 PM
CaddmannQ's Avatar
Busting the slug out with a prybar, and slow grinding, as I use the saw as a gauge.
ID:	171915   Click image for larger version
  #157
Old 10-15-2024, 11:50 PM
CaddmannQ's Avatar
All those tack-welded bits in the rear are welded on solid now. I started doing all the skip welds on the frame rails, but I only got about 12 on before the bottle ran dry.
I ran & got more gas before Fresno Oxy closed, but was too tired to continue.
More tomorrow.
  #158
Old 10-20-2024, 08:55 PM
CaddmannQ's Avatar
The frame rails are fully seamed on the bottom now. That bought me about 5/16” welcome positive camber. I hope to keep some when I weld the top.
Which is indeed on top now, as the frame is back over.
I did have to invert my big clamp to get things on center. It’s still wrong in this first pic.
But now I finally have the frame flipped back right-side-up.
I’ve never seen it in this position before, with the frame rails and firewall crossmember attached.
This is indeed a project milestone.
ID:	171961   Click image for larger version
ID:	171962   Click image for larger version
  #159
Old 10-21-2024, 07:37 PM
CaddmannQ's Avatar
Here is the passenger seat arrangement showing the correct risers.
But these mount the seat directly to the tin floor and that is no Bueno.
  #160
Old 10-21-2024, 07:44 PM
CaddmannQ's Avatar
Originally the car came with four of these seat risers. Unfortunately (and I don’t know how soon or if ever the original builder realized this) they sent him four right seat brackets and no left brackets.
When I got the car the driver seat was mounted all crooked in the chassis because of the mistake.
How I temporarily corrected it is like this.
One of the brackets I cut and welded to make it opposite hand.
One of the brackets I heated up with a torch, and hammered it backwards over an anvil.
All four of them will go in the junk as I am not mounting the seats directly to the floor. Not just because of my scabby welding. That was one of the first things I ever Tig weled with this new machine, and I made a royal mess of it.
Copyright ©2000 - 2025, vBulletin Solutions Inc.
