Old 09-13-2010, 12:44 PM
Default Jack's Way Of Centering A Lathe Chuck On A Rotary Table
With all of the current talk about Rotary tables, after talking to a few people, I will attempt to show how I center the lathe chucks on my rotary tables, that has proven quick, accurate and repeatable.
The attached pics are of the 6", model H7527 rotary table and the 6-3/4", model G9831 plain back lathe chuck, both from Grizzly, the same procedure is used on the 10" RT and chuck, I also use.
The center hole of the 6" RT, is MT#2, so I use a Grizzly model H5895, MT#2 x MT#2 extension. The extension is inserted into the center hole, the chuck (that was drilled to match the RT's slots) is lowered down over the extension, the mounting bolts started, then the lathe chuck tightened onto the extension. At this point the mounting bolts are tightened, chuck opened, and the extension removed. The center of the chuck is now centered onto the center of the RT. All that is required before use is a quick check with a dial indicator and you are ready to go.
1 - the H7527 rotary table
2 - the G9831 plain back chuck, blue arrows the original 3 mounting holes, the red arrows, the new 4 mounting holes, to match the RT slots
3 - the specially made t-nuts
4 - the H5895 MT#2 x MT#2 extension
Name:	RT centering 004x.jpg
ID:	65596   Click image for larger version
Name:	RT centering 007x.jpg
ID:	65597   Click image for larger version
Name:	RT centering 001x.jpg
ID:	65598   Click image for larger version
Name:	RT centering 010x.jpg
Old 09-13-2010, 12:54 PM
5 - the extension in the RT
6 - the chuck on the RT, bolts started
7 - the mounting bolts tight, the extension removed, ready to use.
I've been using this method for quite a while and have had great results, the dial indicator, again is used to prove its centered, but rarely is any further adjustment needed as the B&S indicator needle barely moves.
Name:	RT centering 013x.jpg
ID:	65600   Click image for larger version
Name:	RT centering 016x.jpg
ID:	65601   Click image for larger version
Name:	RT centering 019x.jpg
Old 09-13-2010, 01:03 PM
TriHonu's Avatar
TriHonu TriHonu is offline
Bravo!
I will add this to my short list of things that are: Good, Fast and Cheap.
Old 09-13-2010, 03:37 PM
Scotts Scotts is online now
That is sexy.
Thanks Jack
Old 09-14-2010, 08:20 AM
JohnBoy's Avatar
JohnBoy JohnBoy is offline
Director of Languages
I dont know jack (no pun intended, honset) about machining, but even I can understand that, so simple, but effective.
Old 09-14-2010, 08:49 AM
How do you remove the morse taper extension? My experience with tapers is
I have to bump it from the back end to release it.
Our rotary table has a straight hole in the center.
...lew...
Old 09-14-2010, 09:08 AM
Frank Ford's Avatar
Frank Ford Frank Ford is offline
Schmart and simple!
Once the chuck is centered, you can mount a rod in the mill spindle, grip it with the chuck and then clamp the RT to the mill table to center it under the spindle axis.
Cheers,
Frank Ford
HomeShopTech
FRETS.COM
FRETS.NET
Gryphon Stringed Instruments
Old 09-14-2010, 11:25 AM
Thats exactly how I do it
Old 09-14-2010, 11:38 AM
JohnBoy's Avatar
Yet another random never used a machine tool question......
Once upon a time someone, digr I think, posted some work he'd done where he was almost using a lathe as a mill.
using a chuck on one of these rotary tables could you do basic lathe work on the mill by rotating the part past the spinning mill bit, or would they not be strong enough for that?
Or is that exactly what ye use them for?
Old 09-15-2010, 04:10 AM
matthew_g's Avatar
matthew_g matthew_g is offline
Thats the bestest easiest method I have seen.
Thanks for posting
A society grows great when old men plant trees whose shade they’ll never sit in.
