  #31
Old 08-22-2016, 10:30 PM
I got the gear box out without a problem! I have been procrastinating taking it out not wanting to screw something up. Still haven't found the problem, so far everything looks good.
ID:	135004   Click image for larger version
ID:	135005   Click image for larger version
  #32
Old 08-23-2016, 04:00 AM
Damn, that's a gearbox.
  #33
Old 08-28-2016, 08:25 AM
Well I got the A shifting knob to travel from A-1 to A 3 but it turns very hard when passing A 2. I think the problem was a timing issue with the gears that the A knob turns. The knob turns four gears before the last gear moves the selector gear set. I am gonna have to go in. The A knob shaft is able to be pushed in so there has to be a snap ring missing inside. Who ever was in there before definitely didn't use spanner wrenches because of the shape the nuts are in so the first step is to make spanner wrenches.
ID:	135105   Click image for larger version
ID:	135106   Click image for larger version
ID:	135107   Click image for larger version
ID:	135108   Click image for larger version
  #34
Old 08-28-2016, 12:59 PM
That's a beautiful wrench, Ted.
  #35
Old 09-01-2016, 11:48 AM
I kept digging until I found the problem. I don't know how this could ever happen but a brass gear that positions a selector gear is bent. It never turns under power and only turns when changing gears. It is bent enough so it will not make a full revolution when bolted in place. What do we think is the best idea to straighten a none replaceable gear, The gear has a .5" shaft turned on each end.
1 gear in place
2 removed
3 between centers it is about .0035" out
4 held in a collet it about .012" out
5 gear
ID:	135296   Click image for larger version
ID:	135297   Click image for larger version
ID:	135298   Click image for larger version
ID:	135299   Click image for larger version
  #36
Old 09-01-2016, 11:55 AM
Do you think I could bring it back with some how when it held in the collet in the lathe with a hammer and a brass punch formed to fit the 1/2" shaft?
  #37
Old 09-01-2016, 07:15 PM
very gently in an arbor press. Set up dial inductor to locate high spots and to let you know how far you are pressing. Trial and error fix.
  #38
Old 09-01-2016, 07:34 PM
Which end shaft is bent?
Is it binding because the gear interferes with the gear it mates with or is the bind in the mount blocks?
If it is only a drive to change gears it will not be very critical.
Here are some choices to fix or improve the operation.
You say it is only .0035 out so you can make a close fitting mandrel that slips over the bent shaft and straighten it.
You can grab the gear in a four jaw and turn the bent shaft a couple of thou. You can try adjusting the mounting blocks.
Another option is to loosen the mounting blocks and run a piece of .002 brass shim stock through the tight spot then tighten the mounting blocks.
That may straighten it a little or force the clearances toward a looser fit.
Good luck with this issue
  #39
Old 09-01-2016, 08:10 PM
I got it. It spins free and easy now. It ended up being the short shaft that was bent. It was .015" out. I put the short end in a four jaw, indicated it true and gently beat the other end true within .003" with a plastic headed hammer. I still don't understand how it got bent. Now we will see if I can get it all back together. What do you think blue lock tite or no on the bolts. Some of the high rise lock washers are missing also. Thanks for the advice! I just couldn't wait. It has to spin easy because the brass gear is the last of six gears that the knob turns to move a sliding gear.
  #40
Old 09-01-2016, 08:52 PM
If none of the bolts were loose, I'd not use lock tite.
