Drawing by Smartdraw |
discussed that member, he is now banned as he posted a link to a site that proposed selling equipment, but did not have any contact information. We also think he was using an AI to clean up his language and look very literate in english. Maybe we banned a legit guy, but oh well. In this case not worth the risk. Quote:
Statistical Mechanics. First when we model gases we assume that they are Newtonian in their behavior; meaning the gasses (molecules or atoms) do not interact with each other or with their container. These are considered ideal gases and the ideal gas law applies, PV=nRT. In welding common gases like Argon and Helium are single atoms in the gas, other gases are molecules, such as Oxygen (O2), Carbon dioxide (CO2) or hydrogen (H2) So think of gases as small balls bouncing around in a container where all collisions are 100% elastic. The average kinetic energy is going to be the same every molecule or atom in that mix. And the temperature of the gas is dependently related to that kinetic energy of the gas. The link below does a better job explaining the math than I do. But the key take away is, if you have a mixed gas in a cylinder and the pressure and temperature are held constant and for sake of argument at room temperature, 70F or 18C. These gases will never separate, they will bounce around in the cylinder indefinitely. And therefore cannot separate. Now if the system changes in state, meaning there is a change of pressure or temperature or something else that can interact (chemical reaction) then all bets are off. So lets say we cool our cylinder a lot, -150°C at that temperature and pressure, Argon is still a gas, but you will have solid CO2. Any gas at that point removed from the cylinder will be nearly pure Argon, their will always be a little CO2, due to solubility. We call it partitioning. But we influenced the system by massively cooling it. So you can get separation when you change the state of the system. That is how we purify chemicals. Here is another way of thinking about it. If you have a container, and you have a divider in that container that divides it in half and in one half you have pure Argon, and in the other half you have pure CO2. Also the container is at a constant temperature and pressure, let's say 70°F and 14.7 psi. Now the divider is a magical divider and can be removed with out influencing the gases in any way, other than the barrier is removed. So atoms of Argon and molecules of CO2 that were heading toward the barrier are no longer going to bounce off of it and will head into the opposite gas. Eventually they will bounce of argon, or another CO2 that also moved beyond the barrier or off the containers wall, since all gases are 100% elastic in their interactions no energy is lost in the system, and they continuously bounce around forever mixing. https://en.wikipedia.org/wiki/Kinetic_theory_of_gases https://en.wikipedia.org/wiki/Statistical_mechanics
Now back to Clive's OP. Argon has an atomic weight of ~40 AMU and CO2
has an molecular mass of ~44 AMU. So they are very close respectively. So lets look at my Ar/CO2 example above and change out the Argon for Hydrogen instead. So half the container, contain Hydrogen gases which has a molecular mass of ~2 AMU. So a significant difference in mass. But since the CO2 and Hydrogen are both at 70°F they have the same kinetic energy, so as they bounce off each other and the container, they will retain that same kinetic energy and will bounce around forever mixing. Again to get separation you have to change the state of the system.
Now the other thing that people bring up is trying to explain how CO2 or propane
can build up in a ditch or in a basement etc. Both propane and CO2 have similar molecular weights, ~44 amu; where as the average MW for air is ~ 29. Not a huge difference. But what happens in a system where CO2 or propane can build up to dangerous levels? How do you explain that... In that case you have a source of either gas that is leaking or generating the gas in a confined or semi-confined system where the introduction of the gas is faster than the diffusion of the gases at the interface with the atmosphere. So the concentration can build up locally as the system is dynamic. However, if you secure the leak or whatever is generating the gas and allow enough time the gases will dissipate eventually.
Shade "Prepare to defend yourselves." -- Sergeant Major Basil L. Plumley, Ia Drang Valley Last edited by Shade Tree Welder; 03-27-2023 at 02:21 PM. |
Well done Professor Shade. I no longer have the patience to do that.
...lew... |
I was on a long boring video conf, that should have been an email...
Kind of like this?
I love the smell of napalm in the morning. It smells like, victory! ![]() Rommel, you magnificent bastard, I read your book! Still got the shovel! Victor Torch Set With Meco Regs Lincoln Weld Pak 100 Giant Tech Arc 200 Miller Roughneck2E |
Thanks for posting all that Shade. Very interesting, and I'll have a to read the links a time or 3.
Scott |
I just mute myself and turn my camera off, most of my co-workers do as well.
I did hear someone one time snoring. LOL.
USMCPOP |
