Old 12-20-2018, 12:58 AM
Default Welding Carbon Steel to S.S. With MIG
So it"s been a bit of time since I've used the MIG to weld Stainless
And I need to weld some Stainless to stainless I believe it is 316L to 316L
And Then I need to weld a 4"H x 3"L x 1/4"t, tab of carbon steel to the Schedule 40 316L pipe
So which Wire would I use to weld them both and should I use 98/02 for the gas on this repair or do I need to change gases as well...
I could use TIG but there will be a problem with the wind so I'm opting on using the MIG instead over TIG or Arc rod
SO I need a bit of refresher course please....
Thanks
Old 12-20-2018, 06:49 AM
Mig will have problems with wind too. Stick would be better if you have wind issues. Unless you are figuring that you can shield the wind with your free hand. I generally use 309 filler to weld carbon steel to stainless, but you might need to use 316 since you are welding 316 stainless. Depends on what code is required to follow.
Shade also commented in this thread on this topic.
Tig filler rods to get?
https://www.shopfloortalk.com/forums...d.php?p=726333
Old 12-20-2018, 12:41 PM
requires me to be on a ladder 15 ft. in the air and he want TIG or MIG and TIG is out of the question...….. and base pipe is 316 and will need to attach the carbon steel tab to.
then reweld 9 316 tab pieces back to the main tube which is 316
So would the wire an gas be same for the MIG 316 and the gas 98/02
Old 12-20-2018, 01:47 PM
Normally for stainless you want pure argon. You can probably get by with 98/2 but argon would be better--do an experiment to see what happens. I'd be more concerned about using mig outside, especially if there's any wind. Just because the customer wants something doesn't mean he's going to get it--conditions have to be right...
Old 12-20-2018, 03:00 PM
The company requires either TIG Or MIG preferred Is TIG but being its up in the air TIG will be a problem for me in too many uncomfortable positions
So I opted for the wire feed approach
but yet running in to problems finding spools of stainless in correct alloy and a problem finding Tri Gas they don't even have 98/2 on hand
If it were doable and feasible for me to Use TIG, It would not be much of a problem as I could use argon and the 309 filler rod and 316 filler rod as some of it is 316 to 316L base metal...
And as you mentioned conditions play a big part in it as conditions for the next few days is windy and neither one MIG Or TIG will work as no way to shield the winds...
So I thought using Stick but the company will not accept using stick
An so I am at I either figure it out on how to get it done or walk away from a huge paycheck.... and walking away from this job is really not an option for me because it opens a huge new lucrative doorway for me.... and that alone is hard for me to even consider walking away from it...
Although I will have to run a few practices welds before I jump I to it just because its been awhile since I've run any stainless....
Old 12-20-2018, 04:27 PM
Put a tent around you to block the wind.
Harry S. Truman
Old 12-20-2018, 08:21 PM
The company sent over some test pieces today and are willing to test stick welds if acceptable then they will approve it being in field work only thing...
So they are willing to pay out 4 times MO money for on site than shop fee
an if they approve the stick and it makes since being the cost of moving the equipment would prolly be more
test pieces they dropped off here though are 310 SS to carbon and 304 ss to carbon
So Is there a general arc rod that could be used to weld dissimilar metals
as in weld carbon steel to 316L, 316, 304, 310 SS.
Old 12-20-2018, 11:07 PM
This might help.
Harry S. Truman
Old 12-20-2018, 11:12 PM
This is better.
Harry S. Truman
Old 12-21-2018, 12:41 PM
316 or 309 electrode/filler material. The higher alloy content prevents
carbide formation (embrittlement) in the stainless side of the weld. 309 is
generally recommend because it saves a little money over 316 filler. DO
NOT use 304!
When stick welding have a good bevel as the SS rod do not penetrate well.
But if you prep the parts well the SMAW process is every bit as strong as
Mig or Tig. Whoever is spec'ing out not SMAW is an idiot.
