Drawing by Smartdraw |
It happens when you have a wood shop. Hard to get time to do both hobbies though.
To the OP... Nice find on the lathe. You said you paid too much............so......how much too much? In any given area pricing on lathes and other machinery depends so much on condition and availability. Just because someone else could buy that machine cheaper in another part of the country doesn't mean you paid too much for your locality...
Gerry You got freedom of speech, if you don't say too much. Aaron Neville. When a liberal screams racism, you can bet they were also born with white skin. Common sense is like deodorant. The people that need it most never use it. Joe Concha |
Matt $475 is probably not out of line for that machine.
If it is in reasonable shape. You could part it out and make money. That four lead motor can be either dual voltage or reversible again easy to test just interchange 3 and 4 and power it through a couple of 100 bulbs in parallel. If it turns backwards and the bulbs dim it is reversable . if it hums but does not turn and the bulbs stay bright it is a dual voltage motor. In any case you do not need a drum switch you can make a reversing set up with a simple light switch ( on /off ) and a double pole double throw 15 amp toggle switch. Also a replacement motor can be had pretty inexpensively at flee markets and garbage sales.
Life beats the alternative hands down. Last edited by terry lingle; 02-03-2016 at 03:58 PM. |
Today after work I took the plunge and started working on a sturdy bench for it to sit on; I picked up about 120 lbs of 3x3x3/8" angle iron and spent about 2 hours tonight cutting the pieces for the top frame that will support the tabletop. Either tomorrow or sometime this weekend I'll bevel all of the edges that will be welded and try to get it tacked together. My welder is supposed to be able to handle 3/8" steel at a maximum, so we'll see how this goes. Also pictured is the door scrap I'll be using for the top of the table. Between that, the frame, and a chest of drawers I'll build, I suspect the bench is going to weigh around 300+ lbs empty.
Foot note:
I discovered that a standard, aluminum, bakery sheet cake pan slides right in under the atlas. Makes a really nice, easily dumped, chip pan. When they are too scratched to sanitize, most bakery's will give them to you. I got 26 at one time, just for asking. RED
A 160 MPH drive, down a 2 lane blacktop, all by yourself, is NOT anti-social behaviour... I drag race because football, baseball, and golf only need ONE ball. Paul. What I really need to know is, WHEN DOES THE SHOOTING START? |
Today I mostly finished the bench; just need to add the leg levelers and clean/prep for paint. I plan on making a wooden chest of drawers for tooling that'll fit inside. I think this will be heavy enough. What you see in the picture is about 220 lbs. My 5x6" horizontal band saw got quite the workout. I only broke one tap threading the holes for the bolts to attach the legs
