Old 01-24-2015, 10:16 AM
dpaulson's Avatar
dpaulson dpaulson is offline
Default Radius Guage
I know that there are some pretty clever guys out there, so maybe there is someone that can help me out. I want to make a little tool using a depth guage or a dial indicator http://www.ebay.ca/itm/0-22-540-mm-I..._qi=RTM1963932
to calculate the diameter or radius of a circle from a partially rolled metal. I would make an adapter to mount on the dial indicator to a known distance to represent the chord of a circle (in my .pdf would be 4") and using the measured distance (0.2190) and end result will calculate the diameter in this case to be 18.4838. I can use autocad and draw up each time, but I would like to write a VB app to speed things up. I can write the program, but I need help in the background trig needed for these calculations.
I thought that I was wrong once, but I was mistaken.
David
Old 01-24-2015, 01:20 PM
Here's a section from Machinery's Handbook which deals with mathematics. There is a section called "Segments of Circles" on page 80 which should tell you what you need to know. Page 86 has a table of formulas for "Solution of Triangles" which might also help...
Old 01-24-2015, 03:53 PM
dpaulson's Avatar
Got it. I have attached it if anyone wants to use it. It should help to keep the waste minimal when rolling out circles or part circles.
David
Old 01-24-2015, 05:35 PM
4-13-1949 to 5-21-2023
Saved it. Thanks for the post.
LET'S GO BRANDON!!!!
B biggest
I idot
D democrats
E ever
N nominated
Old 01-24-2015, 06:28 PM
Works for me.
Cool beans, David.
