Old 03-02-2010, 01:14 PM
Cavalry's Avatar
Cavalry Cavalry is offline
Below Wholesale
Default 1835 Mountain Cannon
I decided I needed a cannon! I found some prints for a 1835 Mountain Cannon and reduced them to 37% (golf ball bore)
#1 raw stock. 1144 stressproof
#2 facing end
#3 pilot drill
#4 big drill
ID:	57741   Click image for larger version
ID:	57742   Click image for larger version
ID:	57743   Click image for larger version
Old 03-02-2010, 01:19 PM
Cavalry's Avatar
Below Wholesale
#1 boring
#2 Starting to turn OD
#3 Turning muzzle band
#4 Turning taper of barrel
#5 Taper done
ID:	57745   Click image for larger version
ID:	57746   Click image for larger version
ID:	57747   Click image for larger version
ID:	57748   Click image for larger version
Old 03-02-2010, 01:23 PM
Cavalry's Avatar
Below Wholesale
#1 flipped and facing
#2 band OD
#3 Relieved for cascabel
#4 Taper of breech end. I had to bust out some long forgotten trig to get the angle
#5 Cascabel. My ball turner would not fit this lathe so I did it freehand
ID:	57750   Click image for larger version
ID:	57751   Click image for larger version
ID:	57752   Click image for larger version
ID:	57753   Click image for larger version
Old 03-02-2010, 01:24 PM
Cavalry's Avatar
Below Wholesale
#1 clearing breech band
#2 relieving
#3 Out of the lathe ready for trunnions
ID:	57755   Click image for larger version
ID:	57756   Click image for larger version
Old 03-02-2010, 01:37 PM
Setup boy's Avatar
Setup boy Setup boy is offline
Press One for Trash
Very nice Cav, every well thought out household needs a cannon and a moat Making a present for the Ski Lodge are ya?
Thank you,
Tom(Reformed Post Whore)
This legislation will have the effect of addressing that mal-distribution of income in America."
Sen. Max Baucus Montana
Do you want it right or right now?
Ya can't polish a turd.
The Techie Geek Podcast
Old 03-02-2010, 02:28 PM
Cavalry's Avatar
Below Wholesale
Pretty much. Wonder how long the mountains will ring with the echo?
Old 03-02-2010, 03:05 PM
Setup boy's Avatar
Press One for Trash
they ought to be glad you're making the cannon. Seems like it would do a good job in controlling avalanche conditions
Thank you,
Old 03-02-2010, 03:15 PM
Nice work, you want to make noise get a Harley.
Just for curiosity, mic the od. in three places before you fire it. write that down for the future.
As it's used you maybe-may be able to detect expansion in the barrel over time.
Old 03-02-2010, 04:54 PM
Fla Jim's Avatar
Fla Jim Fla Jim is offline
Harbor Freight Backslider
Did you make an accurate rendition of a "1835 mountain Howitzer" with a reduced powder chamber?
Are you going to make a period 1835 carriage?
There's a black powder cannon forum over on "Graybeard.com".
They have a lot of info on Mountain howitzers.
I got information from there and made a "Golf ball Mortar".
Jim the Shop Rat
From Jim’s Magic Garage®
Old 03-02-2010, 05:45 PM
Cavalry's Avatar
Below Wholesale
Yes, the print showed everything in its entirety. Every thing was reduced to scale (37%)
I am not a big fan of the horse drawn carriage style. Good for display not too good for flopping over on the lawn. I am thinking more of a wheel-less naval carriage that I can stake into the ground solid. Cheap and sleezy.
