  #71
Old 01-17-2010, 11:10 AM
To late about the reducing weight, I cut the center out a bit.
1 layout
2 cut
3 center cut
4 squaring the swivel
5 located hole for adjusting screw
ID:	55800   Click image for larger version
ID:	55801   Click image for larger version
ID:	55802   Click image for larger version
ID:	55803   Click image for larger version
  #72
Old 01-17-2010, 11:16 AM
laid out three holes for backing plate and adjusting screw and drilled and taped.
Went a little under size on the pulley shaft so I had to knurl it, might make a new one later
1 tapping
2,3,4 setup
ID:	55805   Click image for larger version
ID:	55806   Click image for larger version
ID:	55807   Click image for larger version
  #73
Old 01-17-2010, 11:40 AM
OLD MAN's Avatar
OLD MAN OLD MAN is offline
2-3-1940 to 3-8-2011
Nobody was faster
I have 13 pages of drawings, do I have them all?
  #74
Old 01-17-2010, 06:25 PM
LOL I don't know, I have so many drawings I can't keep track of them, maybe if this works out a will make a final set.
  #75
Old 01-17-2010, 06:34 PM
Got it standing up, had a couple surprises, Drilled extra holes for spring adjustment.
ID:	55819   Click image for larger version
ID:	55820   Click image for larger version
ID:	55821   Click image for larger version
  #76
Old 01-17-2010, 10:21 PM
OLD MAN's Avatar
Nobody was faster
You won't know till you have power but based on mine you will need more spring. If the belt vibrates or flutters you need more pull.
I can't do much right now but I will start rounding up stuff tomorrow.
Are you using variable speed? My second one is running 4200FPM and there is little vibration and metal will really disappear. I have tried the orange blaze belts and am now using Alligator back and I like them.
  #77
Old 01-17-2010, 10:28 PM
Direct drive, figures to be about 3400 FPM you must be runnng about a 9.25 DIA pulley with a 1725 RPM motor
  #78
Old 01-17-2010, 11:11 PM
digr, what happened to the tracking adjustment?
  #79
Digr I have bought industrial equipment from big contract builders that didn't look that well thought out.
  #80
Old 01-17-2010, 11:21 PM
Its not on yet
