Old 04-25-2019, 04:16 PM
Default Tractor
Anyone know where the master switch is on this Challenger tractor, I don't know the model number. I have to do some welding on the flail mower. I can always disconnect the battery's but it would be nice to find the disconnect.
ID:	150485   Click image for larger version
Old 04-25-2019, 04:19 PM
Ironman Ironman is online now
Probably no help, but on heavy equipment it is always on the ground side and fairly close to the battery.
Old 04-25-2019, 10:09 PM
SmokinDodge's Avatar
None of the challengers I’ve worked on had a disconnect from the OEM. That’s rare on AG tractors.
Pull the battery cables and keep the ground close to the weld.
Old 04-28-2019, 02:36 AM
Yep Put the ground close to the workpiece as smokingD suggested you will not really even need to disconnect the battery I never disconnect battery anymore. and never have any issues either... but you can just disconnect the ground wire to the battery is all you need, if you feel you must...
