Old 10-07-2018, 07:46 PM
OldRedFord's Avatar
Kibble King
Default D8 final drive leak?
Have a leak going on with the right hand final drive. Or at least I think that's what's going on with it.
What's behind the plate with 4 bolts in the picture?
ID:	147332   Click image for larger version
Tim
Old 10-07-2018, 08:14 PM
Lu47Dan's Avatar
Lu47Dan Lu47Dan is offline
Connoisseur of Old Iron
That plate is your outer axle bearing cover. Probably a blown gasket that is seeping oil.
Get a sharpshooter and clean your tracks. It will make your undercarriage last longer
Dan
Sent from my Samsung J7 using ShopFloorTalk mobile app
Miller XMT-304 Multiprocess
Miller 10-E Wire Feeder
Hobart AC/DC stick welder
Hobart 175 Mig
Craftsman O/A set
Turbo torch and B-tank
Old 10-07-2018, 08:38 PM
OldRedFord's Avatar
Kibble King
Dan
What is a sharpshooter? Pressure washer?
Tim
Old 10-07-2018, 09:05 PM
tnmike's Avatar
tnmike tnmike is offline
Sultan of Scrounge
It's a track cleaning tool. Here is another.
http://www.trackhoe.net/
Klaatu barada nikto
Old 10-07-2018, 09:12 PM
Lu47Dan's Avatar
It is a trenching shovel. D-handle, blade about 3 to 4 inches wide with a radiused nose.
Hobart 175 Mig
Craftsman O/A set
Old 10-08-2018, 09:30 PM
OldRedFord's Avatar
Kibble King
Notes from running it today but only because I had to.
If you pull back on the left steering clutch lever it won't turn unless it's running wide open throttle. Even then there's a delay followed by a noticeable groan from the steering clutch/pinion area and when it does finally start turning you better be holding on.
No difference if I push on the brake pedal. In fact sometimes you can feel it pulse or the clutch lever fights back against you.
Tim
Old 10-08-2018, 09:53 PM
Lu47Dan's Avatar
Sounds like you need to adjust the steering clutch on the left side. Do you have a shop manual on this dozer?
I mean a real CAT manual not the cheesy I&T ones.
There should be a section on adjusting the steering clutch and turning brake.
The groan and shudder is the brake trying to stop a still engaged (unreleased steering clutch) track.
Dan.
Hobart 175 Mig
Craftsman O/A set
Old 10-08-2018, 10:20 PM
OldRedFord's Avatar
Kibble King
Dan.
Been having trouble finding one that covers the adjustment to the hydraulically boosted steering clutches and brakes.
Tim
Old 10-09-2018, 06:26 AM
tnmike's Avatar
Sultan of Scrounge
Check ebay for the manual
Klaatu barada nikto
Old 10-10-2018, 07:02 AM
Default fin al drive bearing/cat manual
yes,second that,get a CAT manual set for the machine if its yours and you're gonna keep it..mine is a 1970,I picked up a Cat manual set off ebay,big three ring binder with ALL the separate manuals(engine,powertrain,chassis,etc) on the machine..even had the update bulletins too..must have for a machine owner!!
