Old 04-08-2018, 12:38 AM
DDA52's Avatar
DDA52 DDA52 is offline
Blood, Sweat & Concrete
I have a 600 footer with a pump depth of 460' or 480'..can't remember which now. I am running a 1.5hp pump. I need to do the same thing, but have decided to get it done. Just a tad more work than I want to do at this point. Besides, my well guy only charges 500 clams to pull and put back the pump.
Don
Old 04-08-2018, 01:36 AM
Samcord Samcord is online now
There are two possible arrangements for well pumps. I just learned this last weekend, out of necessity. 1st arrangement is a two wire pump. This pump will have the startup stuff in the pump. 2nd arrangement is a three wire pump, with the startup stuff in a control box in your pressure tank area. Don’t count the green ground wire. With the green wire you will have three or four total wires.
If you have a two wire, and you need to replace it, get a three wire. It’s a lot easier and cheaper to replace an above ground control box if the startup stuff goes bad, and the total cost will likely be only $100 more, plus the third wire.
Old 04-08-2018, 01:41 AM
And don’t get a lumberyard pump, get one from the well service guy. It will last way longer.
Old 04-08-2018, 08:58 AM
I always use a Gould pump. My well driller neighbor says they last the longest.
Woodrow Wilson
Old 04-08-2018, 09:41 AM
Goulds pump here too. My well driller can pull my 160ft pump swap the pump and have it back in the hole in 2hours at $90/hour its a no-brainer.
All of my wells get a 1hp pump. that way I only need to stock one starter box. I've got 5 waterwells I deal with and will only pull one myself if its an emergency. I cant write off my time but I can w/o the well companies bill.
Old 04-08-2018, 10:11 AM
Doing it with a come-along or a chain hoist--not in my lifetime! I'd be seriously looking for some professional help.
And read Terry's post again. I don't have as much experience as he does but everything he says is bang on...
Yep, I agree. Andy, you got beautiful things to build, let someone else use their skills, and you use yours.
Old 04-08-2018, 11:47 AM
Yesterday, after discovering my pump had gone bad, I backed my truck over to the pump for the tools, and tailgate/workbench. Got some water in the tank, got the pressure pump back online, so I could take a shower and shave, so I could go play my bagpipes at a fundraiser. As I was finishing up, I went to start my pickup and no go. Cranked, but no vroom. I had noticed the low fuel light had come on, so I poured a couple gallons in, which I had brought home for the chainsaws, tools, etc. and I started right up. Maybe I didn't notice the light come on during my last drive home, who knows. I was looking like a very vexing day though.
In the end it turned out okay. I was able to get water working enough to give me time to consider my options. My fundraiser went well, for which I was freshly showered for...
Now, it appears I have a two wire pump. I did speak with two local well guys. Both want to put in a 3 wire pump saying that what I have is outdated, will never last, etc. then they ask how old the pump is. When I tell them it is 17 years old they go on as to how I must not have used it much... then I tell them it feeds 4 houses.
Anyhow, they each have vastly different structures for charging but both end up at about $3,500 to pull and replace the pump. The pump they want to use is roughly $1300+/-, but also need to replace the wire, and neither will include that in their guesstimate, so I am guessing another $1000 for wire.
So by now, I have watched some vids, read some articles, looked at some pump specs. I believe that I will attempt this myself. I have a nice pulley that
I can use for the truck method, or I can bring my gantry crane over and use that. I will also likely replace it with the same two wire pump. I may change the pump wiring to add a motor starter instead of wiring the motor through the float switch. Other than that, if it lasts another 10-15 years I can't complain.
I will keep you posted.
Old 04-08-2018, 12:15 PM
My well is 270' deep, water at 140', pump at 180. It is a 3/4 hp. Put in a new Gould pump, old wire was good. $900. Might have been cheaper than most because the well driller is a friend of mine. 4 hour job. I was the helper.
Woodrow Wilson
Old 04-08-2018, 12:26 PM
Tim KS's Avatar
Tim KS Tim KS is offline
Master Procrastinator
A 600 ft. well is pretty damn deep.
I've pulled my 50' three quarter horse pump twice over the years.....it takes at least two people to do that without problems. I highly recommend Keith's post.
Old 04-08-2018, 12:41 PM
Andy, I must have some gene that refuses to do a job that will fail in a few years. I would get the wire spec,(or Terry can tell you) and go with the 3 wire system. Once you have the spec on the wire go to an industrial electric supplier, preferably one who only sells wire, and get a price. At present, $2 per foot seems high.
Retail price at Homeless Despot in Canada is $900 for 300 meters, which is over 1000ft. Thats $666USD. Industry pricing is always less.
The latest and greatest stuff out there is the tankless system where the pump rotates to give you only what you require. So filling a cup at the kitchen sink means the pump may rotate 10 times and shut off. That is the most expensive. The well boys always push the latest tech.
With the 3 wire, most of what can make you go bald is up on surface, and is newer technology then what you have.
If you want 3 wire, buy the wire and tell them not to include it in their estimate, hell, buy the pump too.
